toneee Posted February 4, 2012 Report Share Posted February 4, 2012 Hi All, I wonder if anyone can help me with an issue I have just noticed. I think I know what the problem is but not how to sort it out. I have an Audi A8 D3 2005 with a water issue, I think the water is coming in through the air vents in the footwells, under the dash (hope that makes sense) This only happens when i corner. So I think the problem is blocked drainage holes in engine bay. The part that is right under the windscreen, that is covered by 2 plastic grills with the air filter in the middle. I have taken the plastic grills off and hoovered out all of the debris that was in there (carless previous owner, lots and lots of pine needles and muck) also I have hoovered out the standing water that was in there too, was about an inch deep int he middle. (see pic below) I have tried to clean this area out as best possible without taking all the bits out, but for the life of me I can't see any drain holes. Can anyone show me where they are or have a picture? Do I need to remove the air inlet to get to them, if so are there any instructions? I think that the last lot of snow just sat on there and melted in and couldn't drain away. Thats issue 1, which has lead onto issue 2. Its been -15 here over the last couple of days and I was a little concerned over the fact I had ice forming on the inside of the windows and had to scrape and then wipe away, after a little more digging i noticed that not only were my floor mats frozen solid, the carpet underneath was too. Very shocked by this. So I guess my next question is how did all that moisture get in? and How do i get it out? Before i noticed how bad the problem was I bought some silica gel (Little hard crystals you get with electronics to keep moisture out) and placed a bit bag in the car, but I now thing this is going to be a bigger issue. Whats the best method of fixing the water ingress, where does it come from? Is the best way to get the moisture out a dehumidifier? I hope someone can help as I am quite shocked that this happens with what was a 50k+ car 6 years ago... T:(neee Link to comment Share on other sites More sharing options...
PsYcHe Posted February 11, 2012 Report Share Posted February 11, 2012 I had this in mine 2 years ago.. was a nightmare for the garage to fix, but I think it's blocked drains as it was worse when wet. Get it fixed quickly as this could cause failures with the MMI and start electronics which live under there! Link to comment Share on other sites More sharing options...
