TVR starting problem
BrettPaulHughes
I have an R Reg Chimaera that is not used over winter.
It was left on trickle charge but not run during this time.
This is not usually a problem for the car.
There is juice in the battery because windows etc work OK.
It is fitted with a Thatcham Alarm / Immobiliser which is disengaged using a fob.
The immobiliser will not disengage and hence the car will not start.
I tried replacing the battery in the fob but no better response.
The immobiliser light on the dash appears to flash on and off and I am sure it is normally a solid on light.
Any ideas?
Thanks
Brett
  • 2 weeks later...
  • 1 month later...
