walto1968 Posted February 23, 2013 Report Share Posted February 23, 2013 my first post and just saying hi not sure this is in the right place if not could you move it please when driving the engine light epc and esp lights come on and stays just wondering if im on the right track on these issus ?????? p0302 cyclinder 2 35-10 intermitton misfire ------------- ?could be loom to injectors plugs ht leads or coil pack problem Component: ESP FRONT MK60 0104 Coding: 0011266 Shop #: WSC 06435 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent,,,,,,,,,,? could be abs pump abs sensors or module on abs pump problem Link to comment Share on other sites More sharing options...
cruiser647 Posted February 26, 2013 Report Share Posted February 26, 2013 Hi! Have you had the coilpacks changed? You could try moving them about and see if the fault follows? ESP - hmmm, not sure. Does your ABS work properly? Does the ESP work too? Link to comment Share on other sites More sharing options...
Cuprabob Posted February 26, 2013 Report Share Posted February 26, 2013 (edited) He As above check coilpacks for misfire. For EPC and ESP lights, check your brake lights work OK as a faulty brake light switch can cause both these lights to come on in the Mk4 Golf Your car has the Teves MK60 ABS pump which has a common failure mode with the G201 sensor, which puts on the ESP light permanently, but I would have expected G201 to be listed in the fault if it was that. Edited February 26, 2013 by Cuprabob Link to comment Share on other sites More sharing options...
walto1968 Posted March 3, 2013 Author Report Share Posted March 3, 2013 Hi!Have you had the coilpacks changed? You could try moving them about and see if the fault follows? ESP - hmmm, not sure. Does your ABS work properly? Does the ESP work too? hi thankyou for the reply i dont think the coil pack been changed by last owner what im going to do first is change plugs then then put new leads on to see if this the problem if i still get a misfire il change coil pack Link to comment Share on other sites More sharing options...
walto1968 Posted March 3, 2013 Author Report Share Posted March 3, 2013 He As above check coilpacks for misfire.For EPC and ESP lights, check your brake lights work OK as a faulty brake light switch can cause both these lights to come on in the Mk4 Golf Your car has the Teves MK60 ABS pump which has a common failure mode with the G201 sensor, which puts on the ESP light permanently, but I would have expected G201 to be listed in the fault if it was that. hi thankyou for the reply brake pressure sensors on the underside of the reservoir/master cylinder. ? Link to comment Share on other sites More sharing options...
cruiser647 Posted March 3, 2013 Report Share Posted March 3, 2013 No, just the brake switch under the brake pedal. Link to comment Share on other sites More sharing options...
walto1968 Posted March 27, 2013 Author Report Share Posted March 27, 2013 just an update only changed the plugs and no misfire turns out that 1 plug failed to spark oh the other thing who ever the last owner was not told that 1 breather hose was broke i put a temp fix on that untill i can get the part as for the engine light and esp light comes im thinking it as something to do with the aircon compressor ever time i switch on the air con both esp and engine light comes on also i get a griding noise form the compressor when on ?? Link to comment Share on other sites More sharing options...
walto1968 Posted March 28, 2013 Author Report Share Posted March 28, 2013 just an update only changed the plugs and no misfire turns out that 1 plug failed to spark oh the other thing who ever the last owner was not told that 1 breather hose was broke i put a temp fix on that untill i can get the part as for the engine light and esp light comes im thinking it as something to do with the aircon compressor ever time i switch on the air con both esp and engine light comes on also i get a griding noise form the compressor when on ?? epc light keeps coming scan saying [h=3]16955/P0571/001393 - Brake Light Switch (F): Implausible Signal[/h] Link to comment Share on other sites More sharing options...
walto1968 Posted April 8, 2013 Author Report Share Posted April 8, 2013 epc light keeps coming scan saying 16955/P0571/001393 - Brake Light Switch (F): Implausible Signal brake light switch changed today no epc light yet Link to comment Share on other sites More sharing options...
