muckel Posted May 6, 2013 Report Share Posted May 6, 2013 Just noticed that when I press the check button on the dash it shows the big red brake symbol, coolant overheating?!! and low oil pressure before Ive even started up. Have reset the service indicator with vagcom but they are still there. Any ideas anyone? Ps the brakes, oil and coolant are just fine. Mind you there is a fault with the temp sensor (intermittent) Link to comment Share on other sites More sharing options...
PsYcHe Posted May 7, 2013 Report Share Posted May 7, 2013 You don't need to press the button... That's normal, it just shows you those symbols even if there is no issue. Link to comment Share on other sites More sharing options...
MichaelV8V Posted May 31, 2013 Report Share Posted May 31, 2013 That button is just a daft toy. If there is a problem, the car will tell you, so why do they give us a button ? Link to comment Share on other sites More sharing options...
Twinspark Posted May 31, 2013 Report Share Posted May 31, 2013 To check that the lights are working? Link to comment Share on other sites More sharing options...
