varcolac1987 Posted May 21, 2013 Report Share Posted May 21, 2013 Hello i have a audi a8 3.0 tdi quattro 2005 i just had the battery and the alternator changed on it and the throttle body.when i put the ignition on is comes up with the error "battery manegement level" and when it starts on the first spin the engine choke's then it starts or it just spins for 6-8 times before it starts. Another thing is that sometimes when it starts for about 1 minute it takes out a white-blue smoke the car drives verry good. Please is there anyone that can help me...i already spent £1000 to change what ever this mechanics have thought is wrong now i just need to be sure...thank you Link to comment Share on other sites More sharing options...
cruiser647 Posted May 21, 2013 Report Share Posted May 21, 2013 Hi, Welcome to TSN! I thinik the car needs to be 'told' it has a new battery. Once done, the car should act accordingly. At the mo, it still thinks the old one is in. Link to comment Share on other sites More sharing options...
varcolac1987 Posted May 21, 2013 Author Report Share Posted May 21, 2013 where or how can i do that? the guy that changed all he did was to take the old one out and put the new one in....and any idea what's with the smoke(someone say'd is the injectors but the car is well strong)?thank you Link to comment Share on other sites More sharing options...
cruiser647 Posted May 22, 2013 Report Share Posted May 22, 2013 You need the VAGCom diagnostics tool. It's software that runs on a laptop that you can connect to your car. Best to get someone who knows what they are doing to do it. The sfotware can be dangerous in beginners hands!!! Link to comment Share on other sites More sharing options...
drpellypo Posted May 22, 2013 Report Share Posted May 22, 2013 The battery does indeed need to be coded. It's the same on the Touareg. Your local dealer can do this for you. Link to comment Share on other sites More sharing options...
drpellypo Posted May 22, 2013 Report Share Posted May 22, 2013 (edited) Oh, and you might find that the battery your mechanic has put in is no good. You can only register the battery to the car if it follows a specific serial number configuration (I think it's 10 digits.) No issues with genuine Audi battery, but it's likely it's a varta or similar which you may run into issues with. Your car will very likely be in 'power save' mode, which will cause driving issues. I'm not sure of the smoke though. I really can't imagine it being related, but it's certainly worth getting the battery issue sorted and seeing how it runs. Edited May 22, 2013 by drpellypo Link to comment Share on other sites More sharing options...
cruiser647 Posted May 22, 2013 Report Share Posted May 22, 2013 Oh, and you might find that the battery your mechanic has put in is no good. You can only register the battery to the car if it follows a specific serial number configuration (I think it's 10 digits.) No issues with genuine Audi battery, but it's likely it's a varta or similar which you may run into issues with.Your car will very likely be in 'power save' mode, which will cause driving issues. I'm not sure of the smoke though. I really can't imagine it being related, but it's certainly worth getting the battery issue sorted and seeing how it runs. Oh no! Mine's a Varta, maybe that's why mine is whinging each time too! Will check the typing Link to comment Share on other sites More sharing options...
drpellypo Posted May 22, 2013 Report Share Posted May 22, 2013 Actually, now i remember, I think Audi might use Varta so you could be OK! Bosch was the one put in my Audi from the dealers. Link to comment Share on other sites More sharing options...
cruiser647 Posted May 22, 2013 Report Share Posted May 22, 2013 I'll do the serial number thing on mine too. See what happens Link to comment Share on other sites More sharing options...
varcolac1987 Posted May 22, 2013 Author Report Share Posted May 22, 2013 thx guys...i will try to get it sorted this weekend will see how it goes... Link to comment Share on other sites More sharing options...
