sapphire1616 Posted September 25, 2013 Report Share Posted September 25, 2013 Hi All, I have a 2002 S8 and recently it has been a real pain to start from cold. Fine when up to temperature. The only way to start it from cold is to push the accelerator to the floor and it will eventually start with lots of smoke from the exhaust and really lumpy running, initially. Is it something I can sort with my limited mechanical knowledge? Thanks Link to comment Share on other sites More sharing options...
cruiser647 Posted September 25, 2013 Report Share Posted September 25, 2013 You can reseat all the plugs, leads. Also, if you can, plug in VAG-Com and check for errors to do with the cam position sensor and crank position sensor. Might just be dirty? Link to comment Share on other sites More sharing options...
sapphire1616 Posted September 25, 2013 Author Report Share Posted September 25, 2013 Thanks cruiser647, I can do the plugs and leads but the rest is a bit beyond me. May have to take it to someone for the rest. Link to comment Share on other sites More sharing options...
Cuprabob Posted September 25, 2013 Report Share Posted September 25, 2013 Sounds like a faulty temp sensor, especially as it it starts with plenty of throttle implying that the mixture is not being made richer for cold starting. Especially if the car starts and runs ok when at operating temperature. Link to comment Share on other sites More sharing options...
sapphire1616 Posted September 26, 2013 Author Report Share Posted September 26, 2013 Where would I find the temperature sensor? Link to comment Share on other sites More sharing options...
Cuprabob Posted September 26, 2013 Report Share Posted September 26, 2013 On 9/26/2013 at 8:40 AM, sapphire1616 said: Where would I find the temperature sensor? I'm not familiar with the S8 but it will be a sensor located in the coolant path, normally in the engine block, with a 2-pin or a 3-pin plug. This might help http://forum.a8parts.co.uk/showthread.php?t=1157 Link to comment Share on other sites More sharing options...
sapphire1616 Posted September 26, 2013 Author Report Share Posted September 26, 2013 Thanks Cuprabob. I will have a look around to see if I can locate it. The article is really helpful. Thanks to all for responses Link to comment Share on other sites More sharing options...
sapphire1616 Posted September 29, 2013 Author Report Share Posted September 29, 2013 Damn car won't start at all now, just fires a couple of times, so is there a way of fooling the sensor to get me mobile again. Link to comment Share on other sites More sharing options...
cruiser647 Posted September 30, 2013 Report Share Posted September 30, 2013 Did you change the temp sensor? On the V6 engines, the temp sensor is just in the V and even on my old V6 TDi I managed to change it. So, might be in the same location on yours? In the V, more on the driver's side, close to the front was where mine was. Did you get VAG-Com onto read the codes? Possible Crank sensor? Link to comment Share on other sites More sharing options...
sapphire1616 Posted September 30, 2013 Author Report Share Posted September 30, 2013 I was going to drive down to get one today...guess the car thought otherwise. VAG-COM states temp sensor reading at -29c. Me in shirt sleeves, I think not. Anyway, I gave up and called the RAC man. Car now gone to local garage to have new sensor fitted. I am going to get one of these VAG-COM thingies. Are they expensive? Thank you to all that responded to me in my hour of need. Most grateful guys. Link to comment Share on other sites More sharing options...
cruiser647 Posted October 3, 2013 Report Share Posted October 3, 2013 You can get a basic Ross Tech VAG-Com thing on eBay for less than £100. Be careful, as some of the cables are crap and some are cable only sales!!! Link to comment Share on other sites More sharing options...
sapphire1616 Posted October 3, 2013 Author Report Share Posted October 3, 2013 Thanks cruiser647. Where does it connect in the car? Link to comment Share on other sites More sharing options...
cruiser647 Posted October 4, 2013 Report Share Posted October 4, 2013 On 10/3/2013 at 10:51 PM, sapphire1616 said: Thanks cruiser647. Where does it connect in the car? Just above the pedals, below the steering wheel - about where your knee is. Link to comment Share on other sites More sharing options...
sapphire1616 Posted October 4, 2013 Author Report Share Posted October 4, 2013 Thanks. Guess you can work out from my questions that I am not very technically savvy. Link to comment Share on other sites More sharing options...
cruiser647 Posted October 4, 2013 Report Share Posted October 4, 2013 No probs on that score Mr! I can do some stuff, but only because:- 1) watched the old man doing it on his car 2) too tight to pay a garage to do some stuff too. Link to comment Share on other sites More sharing options...
