pat27 Posted September 26, 2013 Report Share Posted September 26, 2013 I need to replace the front Discs/Pads on my 2005 3.0tdi, at the moment I cant afford the Audi /Tps brands. Given that I doubt that Audi manufacture them I wondered if anyone has suggestions for a cost effective alternative ?. I am aware of brands such as Pagid, TRWand Bosch etc but I am not aware of the quality of these products. Link to comment Share on other sites More sharing options...
Tipex Posted September 26, 2013 Report Share Posted September 26, 2013 Pagid are pretty good, i've used them many times without issue, just avoid the really cheap brands and you should be ok. Link to comment Share on other sites More sharing options...
pat27 Posted September 26, 2013 Author Report Share Posted September 26, 2013 That must be a record for a reply to a post-Thanks Tipex. Link to comment Share on other sites More sharing options...
cruiser647 Posted September 26, 2013 Report Share Posted September 26, 2013 That must be a record for a reply to a post-Thanks Tipex. You fitting them yourself? Link to comment Share on other sites More sharing options...
pat27 Posted September 26, 2013 Author Report Share Posted September 26, 2013 No I use Autotechnica in Hull, they always do a good job. I have allways used Genuine Audi parts in the past, but at the moment can't justify the extra cost, so I need to know what alternative brand are good. The problem is that so many of the 'recognised' brand names have been taken over, I just dont fancy ending up with a poor quality pad / disc being fitted. Link to comment Share on other sites More sharing options...
PsYcHe Posted September 26, 2013 Report Share Posted September 26, 2013 Pagid used to be good, but the last set I fitted to both my A8 and the wife's XC90 haven't been too great. They work, but aren't so good for spirited driving. Link to comment Share on other sites More sharing options...
snapdragon Posted September 26, 2013 Report Share Posted September 26, 2013 I never really liked Mintex, but took a punt on them as I got a good deal on the A8L's pads and have found them to be the same as the original Audi pads that went before them in terms of 'feel', stopping power and are still lasting well after 25,000 miles. Check the 3 digit codes on a sticker in your tyre well and put them into an online VAG code decoder, this will list the brake sizes you have and the codes are also listed on sites such as EuroCarParts and manufacturer spec-sheets. An example code is 1LL. Link to comment Share on other sites More sharing options...
