AUDI A8 3.0 TDI TURBO
Cornelius Alexandrescu
HELLO GUYS I HAVE A AUDI A8 3.0 TDI QUATTRO 2005 AND I HAVE THE FOLOWING PROBLEMS
-INLET MANIFOLD(WICH I AM ABOUT TO CHANGE)
-AN ELECTRICAL ERROR ON TURBO(WHEN I DRIVE I HAVE NO POWER FOR ABOUT 10 MINUTES THEN THE TURBO GETS BACK)
-MY MECANIC FOUND THAT THE CAR ECU IS CORODED AS WATER GOT IN TO IT.....
-WHAT DO U GUYS THINK I SHOULD DO....DID ANYONE HAD THIS PROBLEM????? THANK YOU
Hi!
The turbo issue might well related to the corroded ECU - You might need to check all the contacts and connectors in the ECU!  After 10 mins, the engine is warm and that might well 'make' a contact work.
Also, check your MAF, might need a clean - your mechanic will know where to find it!
Hope that helps!
  • Like 1
