A8 2004 D3 4.0 TDI - How do I get to the headlight?
Peterparkin
The passenger side ones should just have a standard cover to remove (clips at the top and then arch away and pull up to remove it - don't drop it).
There is bugger all room, so you'll need hands like a child to get in and put them out.  It might just be the bulb and/or the inverter  (if you have Xenons).
Bulbs are about £40+.  Not sure about the inverter.
You local servicing place should be able to do the honors.
I have intermittently had a headlight failure warning on my similar car. Indeed the bulb is "out" - but a couple of days later it comes back on again?!.
The trick to access the back of the headlight is to remove the air cleaner cover - 2 or 3 screws. It's still a sod!
Hope this helps,
John
Hope this helps,
John
Yes of course, the V8 diesel has 2 turbos and 2 air cleaners. +++
  • 2 months later...
