Picture uploading, once up loaded
Calm Chris
Could someone help?
iPad user-
If I have pictures on my iPad they are easy to upload via the attach files at the bottom of the page.
IPad user-
If I have managed (on the desk top) to upload photos to a gallery, how do you then extract those pictures on to a post? I can see them, but can't find a method to extract BCC code, or even copy paste.
Generally the newer vB seems to have gone backward as far as pictures upload and picture management.
Is it the vB or is it the user?
Aside from hosting images elsewhere and then placing a link here, I massively struggle with pictures on here. Are you able to upload pictures from harddrive or do they have to be externally hosted in order to display them in a post?
Someone needs to do an idiots guide....... :blink:
@Torino101
This button will allow you to insert an image.
Depending on where in the community you are posting your message at, you may be able to upload attachments to your message. There are two types of uploaders available: the default uploader and the flash uploader.
Default Uploader
The default uploader allows you to upload attachments one at a time. To begin, press the button. A box will appear for you to select the file on your computer that you want to attach. Select the file you want to upload.
If you change your mind, you can press the button and then choose a different file.
Once you have selected the file you want, press Attach the file.
If there are any errors uploading the file, you will receive an error message, otherwise, you will see the attachment appear.
Flash Uploader
You can enable the flash uploader from your settings menu. When enabled, you will be able to easily upload more than one file at a time.
To start, press Click to Attach Files. A box will appear for you to select the file or files on your computer that you want to attach. Select the file or files you want to upload. You can select more than one file at a time by holding Ctrl (on Windows) or Command (on Mac) and click on the files.
Once you have selected your files and clicked "Open", they will begin uploading. If there are any errors uploading the files, you will receive an error message, otherwise, you will see the attachments appear.
Managing Attachments
Regardless of which uploader you use, once the files are uploaded you will see them on your screen. By default, all attachments are added to the bottom of your message, however, you can add any attachment to a particular section of your post by pressing the "Add to Post" link.
If you wish to remove an attachment and have it not appear in your post, simply press the "Delete" link.
Edited by Andy_Bangle
Useful, as is a bucket with a hole.
It's a pain in the a*se, if I want to post up a pic while i'm out and about (which is where most pictures are taken), I have to email it to myself, so when I get home I can fire up the laptop, download the pic, then upload it to TSN/Flickr etc.
It's one of the only reasons I ever use the laptop these days, and hence I normally can't be arsed to do it, i've got a load of pics on my phone that I thought TSN'ers might find interesting/amusing, but will never upload because it's too much hassle.
It was dead simple on Tapatalk, and I still prefer the Tapatalk interface, shame.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
