gadgetmind Posted January 4, 2016 Report Share Posted January 4, 2016 I have a parking brake error in the MFD of my 2006 D3 and my Vagcom leads shows - 1 Fault Found: 02430 - Left Parking Brake Motor (V282) Resistance to Movement 003 - Mechanical Failure - MIL ON Freeze Frame: Fault Status: 11110011 Fault Priority: 3 Fault Frequency: 4 Reset counter: 117 I think it's due new pads, and is this error likely to clear if the piston is cleaned up? Failing that, just a new motor or whole caliper? Thanks Link to comment Share on other sites More sharing options...
E-bmw Posted January 4, 2016 Report Share Posted January 4, 2016 Don't know your car intimately but seeing "resistance to movement" would lead me to free off, clean, grease where appropriate etc all parts of the handbrake mechanism. Whether that is cables/pistons/calipers/pads/sliders is depending on how yours works. Link to comment Share on other sites More sharing options...
cruiser647 Posted January 4, 2016 Report Share Posted January 4, 2016 In VAG-Com, you can open and close them and also open them for brake pad replacement. Try opening for brake pad replacement and you should hear them both moving. I think it'll be pretty obvious (sound wise) if only the one is heard. If you hear them both, you should see how far the pistons move in VAG-Com - although I had to wind mine in a bit to get the new pads in. (uses a 3 point caliper attachment rather than the normal 2, so I had to find and buy one that fitted the tool - the big motor factor in my town had it) However, try to wind in, and out with VAG-Com first, then maybe the tool to see if it is fooked or if it's the VAG-Com lying to you. Link to comment Share on other sites More sharing options...
gadgetmind Posted January 8, 2016 Author Report Share Posted January 8, 2016 If it is (as seems likely) the parking brake motor, it looks like an easy fix. Anyone done it? Link to comment Share on other sites More sharing options...
