How to get rid of worsening musty smell from Aircon?
Waylander
I've had my cabin filters replaced twice, I've done those Aircon Bombs about 3 times but come summer as soon as you start the car the fungified smell from the aircon is terrible.
Do I need have the whole aircon system drained and regassed?
Not sure what else I can do?
The aircon gas shouldn't affect the smell, surely?  It's a sealed system that purely affects where or not the air gets cold or not.
Sounds like there is a pipe somewhere that is properly foul.  I'm guessing you need professional help, but you could try taking out the heater matrix and seeing if it needs a scrubbing?
It'll be due the build up of bacteria. If the bombs don't work then an an air con anti-bacterial refresh at a specialist should be able to kill it.
It's normally caused by people not using the air con regularly.
See I don't use my air con much, I live in an air condition box all day at work so I don't put it on in the car unless its warm enough to need it and I've never had this issue in any of my cars nor has my better half who does the same.
Apparently putting on max temperature on full power for a couple of minutes, then straight to min temperature for a couple of minutes....and repeat.
This kills bacteria in the system, getting rid of the pong.
Never tried it, but got to be worth a go. +++
  • Like 1
Sounds logical.
I always turn my air con off when I get nearer home after a long trip.
I also, never use it all the time nor even every day.
Yep I do that enough is why I leave it on climate control permanently with aircon always on (learned that lesson from the Audi)
Thanks I've already tried that too with no luck :-(
  • Like 1
Most of those cans you can get at Halfords etc claim to be anti bacterial, I'm not entirely sure a specialist would have any more powerful chemicals? Probably worth seeking one out and asking.
Stripping out to remove and clean the matrix would be such a huge job, you'd need to remove most of the dashboard than it'd need regassing and coolant refilling afterwards, it's just a job so involved it's simply not worth it.
My first action would be to get a torch and look inside every air vent, including the ones under the seat and under the dash, see if you can spot anything untoward in them, I've never had a car that had smelly aircon due to bacteria in the system, I've heard of it before, but assumed it was one of those old wives tales that doesn't really happen as cold air kills bacteria anyway, hence why we refrigerate food.
I don't do anything special with mine to stop it getting smelly, I use it in the summer, not so much in the winter, never switch it off before I get home or anything and it doesn't smell, considering some of the people I pick up, there should be a plentiful supply of bacteria!
Someone vomited in one of the air vents on my old Mondeo, that stank, had to keep stripping back the pipe work until I found the farthest point it had reached and cleaned it all up, sorted it out but wasn't a pleasant job.
Fair point re the matrix.  I'm not used to tinkering with cars that have complicated modern stuff like heaters... :unsure:
No, heat kills most bacteria, cold just slows them down.  Hence why stuff still goes off eventually, even if it's in the fridge.  Also, a fridge goes down to 4 degrees whereas most aircon systems drop the air temperature to 16 degrees at most.
Beat me to it.
Cold is very much the friend of bacteria.
Recent tests have taken ice deposits known to be over 500 years old, melted the ice, waited a while...and found bacteria slowly but surely beginning to move in them.
This is precisely why NASA and ESA are keen to explore ice deposits on Mars - because they're convinced they'll find what can be constituted as life in them - in the form of bacteria.
Edited by NewNiceMrMe
Understood, with regards to A/C going down to 16 degrees, yes that's the coldest you can set the climate control but the temperature of the air is much colder to achieve that, the temperature of the matrix having that air flowing through it will be nigh on zero degrees, you can get ice forming on them in the right conditions.
Maybe leave the heater on full blast for a few hours on a hot day!
Edited by Tipex
The reality is the same at the other end of the scale too.
Warm temperatures don't kill bacteria.   They kill bacteria that can't survive warm temperatures - but far from all.
It isn't too long ago that science thought it impossible for anything to live at very high temperatures.
Then nature decided to say "Hey, scientists, you can all feck off" in quite epic style.
Double-whammy proportions.
At a mile down in the Atlantic ocean, around hydrothermal vents, where the temperature was measured at up to 600 fahrenheit - teaming with bacteria and all manner of much more sizeable creatures (tube worms the width of a mans hand).
Science at the time said this wasn't possible.  For a start, how could tube worms be getting food down there?  They took samples and discovered that their insides were lined with bacteria that oxidize the H2S, turning it into usable nutrients.  The bacteria, in turn, benefit from the relationship because the worms deliver blood-containing hemoglobin, which helps the bacteria to break down the sulfides.
But science is always correct....
p.s. that's without mentioning anything being able to thrive of at such extreme pressures with no sunlight. :roflmao:
