Muppet_man Posted May 31, 2017 Report Share Posted May 31, 2017 Hi all, I have an original MMI standard unit in my A8 4.2 TDi D4 with the very first firmware version. It won't play my hard drive plugged into the USB input with all of my music like my Allroad or my older D3 A8 as it seems the original firmware had lots of bugs. You can play an album, but if you then decide to play something else, you have to unplug it and start again or it won't see any other music as it thinks all of the folders are empty. I took it somewhere to have the firmware (and the maps, which are also old) updated. However the guy couldn't do it (ex Audi technician) because it had such an old version in it. When he went to update it, it told him that it would be updating twelve items when only ten originally existed and that it would possible corrupt the system. Needless to say he wouldn't continue. He therefore can't update it, and instead advised that I should try and get a newer MMI version. Either a later build date version of the same part number which had improved hardware inside which would take the new updates, or, an MMI 3G high plus which has the GSM module in it as well. He said I would need to fit the aerial lead to the shark fin for the GSM, plus Audi would have to remove the security protection when it was installed. Does anyone know if anyone has ever done this swap and succeeded. I would imagine it will need to be coded to get the right fit to the car, but other than that, does anyone have any thoughts or advice. Thanks all. Link to comment Share on other sites More sharing options...
cruiser647 Posted June 1, 2017 Report Share Posted June 1, 2017 Can you upload your hard disc content into the juke box hard disc in the car? Link to comment Share on other sites More sharing options...
cruiser647 Posted June 1, 2017 Report Share Posted June 1, 2017 Although, in me saying that, I have yet to load any CDs into it. And just have songs on an SD card. Link to comment Share on other sites More sharing options...
Muppet_man Posted June 1, 2017 Author Report Share Posted June 1, 2017 Hi, that part works fine. However I have (as I do in all my other Audi's) a 500GB hard drive full of all of my own music. This is the only car that it doesn't work in. Than's why I want to get the upgrade/update. Link to comment Share on other sites More sharing options...
