Cruise retrofit for Audi A4 8H Cabrio
davies46
Looking for someone down south, ideally Hants area, to install a cruise control into this nice Audi I just bought. Happy to drive but Mansfield's a bit far for me ☺️
I've almost worn Google out over the last few days and got nowhere, maybe my search terms are all wrong!
Thanks for any advice,
Phil
  • 3 weeks later...
  • 1 month later...
When it comes to retrofitting cruise control in an Audi A4 8H Cabrio (convertible), it is essential to consider a few factors.
  1. Compatibility: Firstly, ensure that your Audi A4 8H Cabrio is compatible with a cruise control retrofit. It's advisable to consult with an Audi dealership or a trusted automotive specialist to confirm compatibility.
  2. Retrofit Kit: Once compatibility is established, you will need a cruise control retrofit kit specifically designed for your Audi A4 8H Cabrio. These kits typically include the necessary components such as a control stalk, wiring harness, and possibly additional modules.
  3. Installation: Retrofitting cruise control usually involves installing the control stalk, connecting the wiring harness to the appropriate modules, and programming the vehicle's control unit to recognize and activate the cruise control function. It is recommended to have the installation performed by a qualified mechanic or technician experienced in retrofitting Audi cruise control systems.
  4. Programming: After installation, the vehicle's control unit may require programming or coding to enable the cruise control function. This step ensures that the vehicle's systems recognize and properly respond to the cruise control commands. It is typically done using specialized diagnostic tools and software.
To proceed with retrofitting cruise control in your Audi A4 8H Cabrio, it's advisable to consult with an Audi dealership or a reputable automotive retrofitting specialist. They can provide accurate information regarding compatibility, recommend suitable retrofit kits, and perform the installation and programming process correctly. camping with dogs
