krusty Posted April 16, 2004 Report Share Posted April 16, 2004 The 'Emissions Workshop' warning light on my 1.6 16v '03 Golf keeps lighting up. At first, the warning light flashes whilst the engine is clearly misfiring, then after several minutes, the light will remain on and the engine will appear to run ok. The car has been back to the dealer four times in the last 10 days to have it sorted and within a few hours of collecting it from them, exactly the same thing happens again. All the dealer seems to do is change the coil packs and the EGR valve. Other than that, they seem to be at a total loss as to what to do. Has anybody come across this problem before and if so, what's actually wrong with the car as the 'fitters' at the dealer clearly haven't got a clue. Any help or assistance is much appreciated. Link to comment Share on other sites More sharing options...
clapton Posted March 22, 2005 Report Share Posted March 22, 2005 I am having the same problem as you describe. Did you ever manage to get the problem resolved ? Under warranty ? Thanks Link to comment Share on other sites More sharing options...
cb02aaj Posted April 3, 2005 Report Share Posted April 3, 2005 Hi; i have a MK4 Golf 1.6 SE 16v (02) and got the same problem. My local vw specialist is struggling ti fix the problem; the light comes on; the car miss fires starts driving real slow; i switch engine off wait and restart; then usually missfiring goes away; then light goes away. My mechanic does the diagnostic test; it always says plus 2 miss fire. i have changed all the coil packs, put new spark plugs in still the problem occurs. then my mechanic said it was the temperature sensor; put it in did not work; waste of 30 pound. Then he said it is the lampda sensors also known as oxygen sensors (cost 230 for both) put them in last week; still not fixed; taking it to him again tommorrow; he gonna try again. i dunno whats wrong; he said to me he confused to whats actually wrong; any luck let me know what was changed; i will do vise versa if i get somewhere tommorrow. good luck Link to comment Share on other sites More sharing options...
THEBLUER32 Posted April 5, 2005 Report Share Posted April 5, 2005 Hi, check the cylinder compressions, carry out a cylinder leak test and check the oil pressure. I am not telling your mechanic how to suck eggs but remember to keep it simple and don't forget the basic engine fundermentals. Link to comment Share on other sites More sharing options...
jamesbland Posted June 19, 2005 Report Share Posted June 19, 2005 I had this problem. It caused my car to completly stop and not restart, several times. After going back and forward to the garage, it turned out to be the EGR valve (something that recurculates the exhaust emmisions). Turns out i had small slithers of metal caught up in the piston of the EGR valve. Since picking these out i have had no problems. Hope this helps. Link to comment Share on other sites More sharing options...
dubber66 Posted October 23, 2011 Report Share Posted October 23, 2011 Tried the above for my golf mk4 1.6, Car judders when accelerating could this be the coil packs on each spark plug. Link to comment Share on other sites More sharing options...
