S858DGD Posted April 29, 2004 Report Share Posted April 29, 2004 Can anyone assist me in telling me how to remove the trim to get into the sub on the left side of the boot. The last thing I want is to miss a screw and end up breaking a clip and have it rattle from now to eternity. Any help would be gratefully accepted. Link to comment Share on other sites More sharing options...
Tomk Posted April 29, 2004 Report Share Posted April 29, 2004 you will need to remove the rear quarter and seat, there is a screw behind that , 2 by the bumper near the boot floor , remove the luggage hinges, and also the light under the trim, if you are taking it out replace the sub with a custon built 6.5 inch one , will sound the dogs! ive dont all that in mine Link to comment Share on other sites More sharing options...
S858DGD Posted May 4, 2004 Author Report Share Posted May 4, 2004 Was trying to replace the standard fit sub with a bose sub but loom is totally different. Got any ideas how much work is involved in replacing the existing loom? Bose system must be fed through an amp. Dont suppose anyone has atempted this successfully Link to comment Share on other sites More sharing options...
Tomk Posted May 4, 2004 Report Share Posted May 4, 2004 ive been down this route , bose sub will not work , and anwyay does not sound any better, you are better off making your own sub enclosure, you can fit a 6.5 " sub in there , install an amp in the rear quarter and run this to the headunit , it can all be done for about 250 if you do it on the cheap , ive got my car all sorted out , though ive used a aftermark head unit , pm me and ill fill you in Link to comment Share on other sites More sharing options...
