audia8s2 Posted May 14, 2004 Report Share Posted May 14, 2004 Hi guys, quick question for you, I was scanning through the Bentley repair CD yesterday and came across comments about the "accelerator kick down switch". Bascically my kickdown doesn't seem to be as precise as it used to be. Unfortunatley my CD won't read anymore so I never got to the bit about where it is??? is it a physical switch on the throttle body/accelerator setup or is it actually controlled by the ECU? Thanks Ben. Link to comment Share on other sites More sharing options...
PaulW Posted May 16, 2004 Report Share Posted May 16, 2004 On the pre face lift cars it's on the throttle linkage I believe and on the post face lift cars it's where the gas pedal hits the floor. Link to comment Share on other sites More sharing options...
audia8s2 Posted May 16, 2004 Author Report Share Posted May 16, 2004 Thanks Paul, your right, it's on the throttle body. I had a play with the kick down unit yesterday, made some adjustments and also took the slack out of the accelerator cable. Everthing seems to be back to normal now. Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 16, 2004 Report Share Posted May 16, 2004 Very, very selfish of you, your local dealer could have charged you thousands for another g/box! Just think of their balance sheets next time would you... Well done Talking of g/boxes, I noticed that mine has been nodding off to sleep and then waking with quite a harsh change accompanied by a bit of a bang when all that has been req'd was a gentle down shift Link to comment Share on other sites More sharing options...
AnArtist1 Posted May 16, 2004 Report Share Posted May 16, 2004 Talking of g/boxes, I noticed that mine has been nodding off to sleep and then waking with quite a harsh change accompanied by a bit of a bang when all that has been req'd was a gentle down shift [/ QUOTE ] That is exactly what mine does especially when you need to hop round traffic on the motorway. Gentle squeeze on the throttle and !!!bang!!! then you start moving. Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 16, 2004 Report Share Posted May 16, 2004 Mines @ very low speed when easing the throttle on. Think that cause I'm easing in the power whilst the slushy change of the box changes, it may be that I'm adding gas whilst the box is shifting. Where as I'd nomally just add a big dollop of gas and let the box catch up. Does that make sense? ) Link to comment Share on other sites More sharing options...
audia8s2 Posted May 16, 2004 Author Report Share Posted May 16, 2004 I think I may have mentioned this before but it sounds like bit of slack in the propshaft. Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 16, 2004 Report Share Posted May 16, 2004 Did I forget to mention mines front wheel drive... Link to comment Share on other sites More sharing options...
PaulW Posted May 16, 2004 Report Share Posted May 16, 2004 If you have never changed the automatic transmission fluid and filter, do it now....your transmission will thank you and it will work so much better. Here is a detailed procedure, bring it to your trusty German mechanic, it's easy to follow. Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 17, 2004 Report Share Posted May 17, 2004 I was gonna go through the service book today. I dont even remember seeing a dipstick for the ATF under the bonnet/hood (there sure enough is one behind he wheel in my car ) Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 18, 2004 Report Share Posted May 18, 2004 [ QUOTE ] If you have never changed the automatic transmission fluid and filter, do it now....your transmission will thank you and it will work so much better. Here is a detailed procedure, bring it to your trusty German mechanic, it's easy to follow. [/ QUOTE ] Spoke with the stealer, they want £260 inc that vat (less my discount ). Will check in the service book/invoices if it's been done recently. Will go check your link now+++ Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 18, 2004 Report Share Posted May 18, 2004 [ QUOTE ] Will go check your link now [/ QUOTE ] Top artcle Paul! For £260 quid the stealer can do all that You guys and gals on TSN are really the most Link to comment Share on other sites More sharing options...
PaulW Posted May 18, 2004 Report Share Posted May 18, 2004 What is a quid? Is that a pound? How much is that is U.S. dollars? Just curious. Link to comment Share on other sites More sharing options...
Sven Posted May 19, 2004 Report Share Posted May 19, 2004 $1.76494 according to www.xe.com Link to comment Share on other sites More sharing options...
Sven Posted May 19, 2004 Report Share Posted May 19, 2004 Hey! Buy now! It's going up! $1.76514 now! Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 19, 2004 Report Share Posted May 19, 2004 [ QUOTE ] Hey! Buy now! It's going up! $1.76514 now! [/ QUOTE ] Link to comment Share on other sites More sharing options...
Sven Posted May 19, 2004 Report Share Posted May 19, 2004 Still going strong! $1.77646 now! Now Paul, if you only had taken my advice and bought, let's say 10,000,000.- of them, you'd have made enough for a brand spanking new A8 overnight. Fascinating thought tho eh? Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 19, 2004 Report Share Posted May 19, 2004 Careful PW. Sven_S8 could be about to try a "Nigerian shuffle" on'ya. Next he'll be asking you for your bank details, just so he can transfer $14M US into your account from some African Goverment dept You've been warned Link to comment Share on other sites More sharing options...
PaulW Posted May 19, 2004 Report Share Posted May 19, 2004 Oh....I know Sven and his tricks! Link to comment Share on other sites More sharing options...
Sven Posted May 20, 2004 Report Share Posted May 20, 2004 Hmpf, are you trying to be helpful, next thing you know you're being labeled as a Nigerian. :mutter: And you, mister instigator, don't be surprised if your nick is suddenly chanced into CheekyMcC.... Link to comment Share on other sites More sharing options...
Sven Posted May 20, 2004 Report Share Posted May 20, 2004 BTW, it's $1.78281 now.... (Wait a bit and those bi-turbo's may become very tempting...) Link to comment Share on other sites More sharing options...
SneakyMcC Posted May 20, 2004 Report Share Posted May 20, 2004 [ QUOTE ] And you, mister instigator, don't be surprised if your nick is suddenly chanced into CheekyMcC.... [/ QUOTE ] Hey, CheekyMcC? Does have that ring to it Link to comment Share on other sites More sharing options...
