A8 Kick down switch
audia8s2
Hi guys,
quick question for you, I was scanning through the Bentley repair CD yesterday and came across comments about the "accelerator kick down switch". Bascically my kickdown doesn't seem to be as precise as it used to be. Unfortunatley my CD won't read anymore mad.gif so I never got to the bit about where it is??? is it a physical switch on the throttle body/accelerator setup or is it actually controlled by the ECU? confused.gif
Thanks
Ben.
Very, very selfish of you, your local dealer could have charged you thousands for another g/box! Just think of their balance sheets next time would you...
Talking of g/boxes, I noticed that mine has been nodding off to sleep and then waking with quite a harsh change accompanied by a bit of a bang when all that has been req'd was a gentle down shiftEEK2.GIF
That is exactly what mine does especially when you need to hop round traffic on the motorway. Gentle squeeze on the throttle and !!!bang!!! then you start moving. confused.gif
Mines @ very low speed when easing the throttle on. Think that cause I'm easing in the power whilst the slushy change of the box changes, it may be that I'm adding gas whilst the box is shifting. Where as I'd nomally just add a big dollop of gas and let the box catch up. Does that make sense? smashfreakB.gif)
If you have never changed the automatic transmission fluid and filter, do it now....your transmission will thank you and it will work so much better.
Here is a detailed procedure, bring it to your trusty German mechanic, it's easy to follow.
Spoke with the stealer, they want £260 inc that vat (less my discount wink.gif). Will check in the service book/invoices if it's been done recently.
Will go check your link now+++
