TMC dynamic traffic information active in Touareg
If anyone is interested in seeing the dynamic traffic information working in the Touareg...
Apologies for the low-quality phonecam images, but you should get the idea:
Image 1: Map shows congestion on road "M4" - with dashed blue/red color-coding and warning triangle image (bottom right).
Image 2: List of current traffic alerts in local area (30-40 miles or so)
Image 3: Detailed info on individual traffic report
Image 4: Showing the TMC as logged-on to radio signal, and 6 current traffic messages
You do need a special Nav disk to make this work in the UK (not supplied by VW......), but once set up, seems to work reasonably well.
  • 1 month later...
Trapdoor,
VW dealer probably clueless because VW insistent it doesn't work..... No subscription charge (assume is included in disk price). Works similar to RDS; signal comes through on the Classic FM frequency, which the disks are pre-programmed to lock onto.
Got mine from satnavshop.com but might be cheaper (if not entirely legit) examples on eBay.
Hope that helps.
Matt
