grahamb Posted October 22, 2004 Report Share Posted October 22, 2004 Are they on all the time, or do I have to switch on the heated rear window to get them to heat up? Over the past couple of weeks, I've noticed that they aren't clearing the mist off of them. Blown fuse? Wifey just pointed out that the wipers when on intermittent, the delay increases when stationery, and then the delay shortens when I'm moving again. Never noticed until she borrowed the car for two days last week! Cool Link to comment Share on other sites More sharing options...
JoeNobody Posted October 22, 2004 Report Share Posted October 22, 2004 I think they're on if the rear windscreen heating is on. Link to comment Share on other sites More sharing options...
Paul Posted October 22, 2004 Report Share Posted October 22, 2004 on my S3, they are are automatic IIRC. come on and off as needed when the temp drops below a preset limit of 5 degees (i think)?? Link to comment Share on other sites More sharing options...
beefer1mckee Posted November 10, 2005 Report Share Posted November 10, 2005 hi all, just purchased a 2005 A3. it is an import from ROI. one annoying trait is that there are no heateed wing mirrors! the wiring appears to be there. i have tried fitting glass with heating elements but this does not work. anyone any ideas how to get them working? cheers b Link to comment Share on other sites More sharing options...
citizen Posted November 10, 2005 Report Share Posted November 10, 2005 "The mirror surfaces are heated according to the outside temperature when the ignition is on"..... according to Manuel and my experience! Also, I was convinced the intermittent wipers were speed dependent and Manuel again confirms this... Link to comment Share on other sites More sharing options...
beefer1mckee Posted November 10, 2005 Report Share Posted November 10, 2005 yeah i saw that in the manual. however it was 3 degrees celcius the other day, and they did not come on. i have tested to see if the wires are linked in a circuit and they are however they are not powered. someone has suggested the control unit needs reprogrammed to make them work. anyone know? Link to comment Share on other sites More sharing options...
Edd_W Posted November 11, 2005 Report Share Posted November 11, 2005 You might need to use VAG-COM to set up the option so they get power? In earlier A6's they come one with the HRW but later ones are outside temp dependant. I beleive there are on the same circuit as the washer jets - hope this helps. Link to comment Share on other sites More sharing options...
beefer1mckee Posted November 11, 2005 Report Share Posted November 11, 2005 is it worth buying a vag com to do this or would i be better going to a dealer and getting it switched on? spoke to audi in dublin, and they did not have a clue! i assume that as the wires are in a circuit it is just a matter of telling it to work via the vag com. would it be a complicated task to do this via vag com? Link to comment Share on other sites More sharing options...
Edd_W Posted November 11, 2005 Report Share Posted November 11, 2005 I am not totally sure that is the problem but it a fair guess. If you look on www.audiworld.com there is a forum and quite recently in the A6 - B5 forum there was a link to a VAG-COM locator. There might be someone near you who will look for a few beers or bottle of wine. Try searching there. Link to comment Share on other sites More sharing options...
marko96 Posted January 20, 2006 Report Share Posted January 20, 2006 On my A6 they operate when the button for clearing the windscreen is on. Link to comment Share on other sites More sharing options...
nicknick Posted January 20, 2006 Report Share Posted January 20, 2006 They don't work on my A6 (one of the very first C5's - April 98) ..but that's (apparently) because they were powered all the time (though I've read / heard that Audi changed the way they work several times...hence the many different suggestions as to when they are on) and it's a common fault for the element in the glass to burn out. I've also heard that replacement glass has a thermal cutoff to poentially avoid this problem . Link to comment Share on other sites More sharing options...
Hudson Posted January 29, 2006 Report Share Posted January 29, 2006 I have a 99 2.8 quattro and mine do not work, then again i am not even sure if i have them !!!! Were they standard ? Link to comment Share on other sites More sharing options...
UBM Posted January 29, 2006 Report Share Posted January 29, 2006 Buy the spares from www.vagparts.com, even if they weren't heated to start with, the wires should be there Link to comment Share on other sites More sharing options...
