How much "power "can the haldex system handle ?
dazmondo
Does anyone have any idea whats the maximum bhp and torque the 4wd system can take before splitting at the seems,
im enquiring cause in the near future, a pacemaker may be attached to my beasts heart, i know HPA of north america do a excellent gearbox upgrade so im sure that somewhere in the UK the same can be achived.
Not looking forward to the MPG if itdoes happen but the grin should be worth it. grin.gif
The official numbers vary between 1500 and 2000Nm torque - so at least 5 times what a std R32 puts out from the engine (320Nm).
The standard R32 gearbox is only rated to something like 346Nm, so the Haldex diff is pretty irrelevant in the power quest unless everything in front of it has been substantially beefed up first.
That is why part of the HPA (HGP) upgrade is new gearbox internals...
Don't be misled by those torque numbers. Most people forget
that the transmission and final drive are torque multipliers.
The Haldex unit is downstream of the transmission
and the front diff. The prop shaft to the Haldex unit
turns at a 1 to 1 ratio with the rear drive axles.
If you're in first gear, which has a ratio of 3.36:1 and
the final drive ratio at the front diff is 4.24:1 then you
effectively have a torque multiplication factor of 14.25 to 1.
That means if the engine is producing 300Nm of
torque at the crank, it's putting out 4273 Nm of torque
at the front diff. Let's say it only takes 2000Nm to
spin the fron tires, that'll leave over 2200Nm of torque
going to the Haldex unit. In other words, even
a bone stock R32 can exceed the rated load capacity of
the Haldex unit in 1st gear, given the right traction
situation.
As you go up through the gears, the torque post-final-drive
decreases. Haldex also has hydraulic pressure overload
protection. When it reaches it's maximum load capacity, it
simply starts to bleed off extra pressure and clutch
pressure remains constant. This may mean some slippage
in the low to mid gears (2nd and 3rd), and front wheel spin
if you're putting down HPA stage II or EIP stage IV kind of
power numbers, but generally there's still enough torque
going to the ground that the accelleration is still pretty
mind blowing (0-60mph in 3.2 seconds.. quarter mile in
11.2-11.5, top speed over 200mph), all with the stock Haldex unit.
EIP has been researching ways to push the torque limits of
Haldex up, but then they're also putting down 600+fwhp.
Not a problem most folks have to face.
ian
Sure it will, there are loads of SC R's running round the USA now some with stage 1 and some with stage 2 conversions.
If I were you I would hold out a bit longer as the low priced turbo kits are about to start hitting the market now and seem to give more bang for your buck. EIP now have a UK distributor for there kit (can't find the link suicide.gif)
cheers
matt
