1977 530i Automatic does not shift.
willison
Help
My automatic transmission on my 1977 BMW 530i (zf 3hp-22) will not shift up through the gears when it is cold. After it has warmed up (5 minutes), it seems to work fine. I have changed the filter & put in fresh fluid but the problem persists. Does anyone have any ideas that might cure this problem. Is there a magic additive out there that I could try ? Any input on this problem would be greatly appreciated.
Thanks
Mike........
  • 5 months later...
When you changed the filter, did you see two magnets at the bottom of the sump and if so, did they look like hedgehogs?
I had the same symptoms as you and now my Alpina gearbox is pressurising - forcing up fluid through the dipstick tube.
New gearbox is on order...
Best wishes,
Ram
