Cheap Ebay Cables?
Crusader01
Oh yes. When you buy a cheap cble, you only get to use the freeware version of the Vag com software. To register and upgrade to full software will cost about £100. This allows you to use it on one computer, then if you want to use another computer you have to un-register, and re-register it.
When you buy a pukka Vag com, it comes with a built in software "dongle" which means that you can use the cable and software on any computer, with full functionality.
Also, the tech support with the proper cable is excellent. If you buy your own cable, then contact Ross-tech with a problem, the answer will understandably be "Ask the cable seller!"
Seems to be a minor gathering of A8 & Ex A8 here.....
I just want to change some settings on my Nav Unit, not going to touch anything else not wanting to turn a drama into a crisis.
So basically bar the software functionality the cables are much the same?
I have got one thats collecting dust but it came with the 4 wires unconnected to the red socket so its pretty much useless.
Regards
C
I bought the full version, I wish I had bought the cheap cable version as Ross tech support as been of no help what so ever.
Who did you speak to?
They are the most helpful company I have ever delt with.
Not sure what happened there but there customer service is normally excellent.
Or look at it this way, If you own another make of car and want something like VAG-COM you will pay £1000-30,000 pounds for the same thing, which makes £200 look very cheap.
Hi Tobes49,
I enquired several times about secret key codes, they took time answering me, and did not even take the time to read my email properly.
They just said they do not provide secret key codes in a very kurt email. If they had taken the time to read my email it would have been apparnet that, that was not the question I was asking.
