TVR Chimeara
artygall
Would be greatful for any info on Chimeara alarm ,I have just replaced the battery and now the alarm sets off everytime I try to set the alarm.Does anyone know where the alarm control box is located, I have a key to reset the alarm but can't find where to put it! Thanks Artygall
  • 2 weeks later...
  • 3 weeks later...
Ribol, thanks for the reply.I have now found out it's location.Its a Meta 199T and is situated under the dashboard,the top of the dashboard has to be removed to reset it! A job for a long weekend.Many thanks for your help. Artygall
Getting the dash top off is not as bad as people make out, glove box bag off(2 x screws), dash top(3 x 10mm nuts). Have you tried disconnecting the battery for 30 mins and trying again? Sometimes works. Good luck!!
  • 2 weeks later...
Ribol, many thanks again, I haven't left the battery off for longer than 5 mins so will try over night before I lift the lid. If the pic on your reply is your Chineara we have the same colour . Must swap plate details sometime. Will let you know if the dis-connection works. Many thanks Artygall.
  • 6 months later...
