vag.com and phone mute for RNS-E
rjgreen4
I have had the RNS-E installed and need to have vag.com enable the mute function for the installation of a hands free kit.
I have spoken via e-mail to Phill about vag.com and he has generously said that he will assist but I need the code,
Not sure where to start with the code
** Radio/navigation system (Rns e) **
Controller coding
STG 56 (radio/navigation system) select
STG coding - > function 07
0?xxxxx : Vehicle
1 - AUDI a2
2 - AUDI A3 (8P)
3 - AUDI A4 (starting from MY 2004)
4 - AUDI A4 Cabriolet (starting from MY 2004)
5 - AUDI A6 (to MY 2004)
6 - AUDI TT (starting from MY 2004)
0x?xxxx : Fault-tracing
0 - Fault-tracing for front loudspeakers actively
1 - Fault-tracing for front loudspeakers inactively
0xx?xxx : Sound characteristic
0 - linear sound characteristic
1 - AUDI A4 (starting from MY 2004)
2 - AUDI A6 (to MY 2004)
3 - AUDI A4 Cabriolet (starting from MY 2004)
4 - AUDI TT (starting from MY 2004)
5 - AUDI A3 (8P)
9 - Bose sound system
0xxx?xx : Telephone/telematics
1 - No telephone (supply voltage for microphone actively)
2 - Handyvorbereitung (Temic - Speisesp. Microphone inactively)
3 - Handyvorbereitung (Cullmann - Speisesp. Microphone inactively)
4 - Handyvorbereitung (Nokia - Speisesp. Microphone inactively)
5 - Telematics Europe (supply voltage microphone inactively)
6 - Telematics US (supply voltage microphone inactively)
0xxxx?x : Austattungsoptionen I
1 - no additive zusatz-Tuner
2 - Digital radio
3 - Satellite radio
4 - Satellite and digital radio block
0xxxxx? : Austattungsoptionen II
1 - no TV tV-Tuner, CD change-over switch or multi-function steering wheel
2 - TV tV-Tuner available
3 - CD change-over switch available
4 - TV tV-Tuner and CD change-over switch available
5 - Multi-function steering wheel available
6 - TV tV-Tuner and multi-function steering wheel available
7 - CD change-over switch and multi-function steering wheel available
8 - TV tV-Tuner, CD change-over switch and multi-function steering wheel available
Not sure if that is any use to you RJGreen?
Whats your car type and do you have bose?
If this works I'd like potato wedges with cheese.
For example...
0 = leading first number always 0
3 = Audi A4
0 = check fron speakers off ( not needed with bose )
9 = Bose
1 = No Telephone
1 = Standard Tuner
3 = CD Changer
Code = 0309113
Make a note of the current code from module 56 or 37, they are both the same module. And then recode to suit your needs. If you don't undertsand VAG-COM then don't try and use it.
I have an A4 (B7) 2.0T QUATTRO SLine, 1 month old, with RNS-E and Bose,
will that code still be applicable, ther person who will be performing the task is Phill ( registered on the VAG.com list).
If you can arrange the code for me/phill to do, I will sort you out with some beers like I have offered phil.
Richard
Managed to get Rich's car sorted out in the end, no k-line on the loom or BOSE pin fitted for BOSE system. Added those to the loom, but still no mute. Tried all 6 combinations of code for the phone kit, no joy.
Upgraded the sat nav to version 0100 (2005 disk) and the mute started working. But unfortunately the speakers for the phone did not work, as this was a 3rd party Parrot kit, Richard took it back to the vendor after I had checked it out. They told him the speaker wires were not connected to the unit, they seemed ok to me, but it's working now.
