brownswood Posted May 17, 2005 Report Share Posted May 17, 2005 does someone fancy showing a newbee the ropes? Link to comment Share on other sites More sharing options...
Scotty Posted May 17, 2005 Report Share Posted May 17, 2005 Diagnosis software : www.ross-tech.com Link to comment Share on other sites More sharing options...
brownswood Posted May 18, 2005 Author Report Share Posted May 18, 2005 i wanted to set my doors to auto lock as i drive over a certain speed and unlock on accident/igniton off can this be done with this software? and is the software freely avaialble? cheap/expensive? hard to use? thanks Link to comment Share on other sites More sharing options...
Wobby Posted May 18, 2005 Report Share Posted May 18, 2005 I want to do this as well, i have VAG COM cable, just need to know what to do on a 2001 Passat TDI. Anyone Link to comment Share on other sites More sharing options...
sk Posted May 18, 2005 Report Share Posted May 18, 2005 Try this http://www.wak-tt.com/vagcom/vagcomclcoding.htm Link to comment Share on other sites More sharing options...
Wobby Posted May 18, 2005 Report Share Posted May 18, 2005 Thanks, juat the job. Will it work on my 2001 Passat?? Can i do damage if i use this coding and its wrong? Or can i just put the previous code back in to revert back to previous settings? THanks RobK Link to comment Share on other sites More sharing options...
Paul Posted May 18, 2005 Report Share Posted May 18, 2005 vw may be coded differently. ive looked into doing it on brothers golf, and its not the same as Audi method. Link to comment Share on other sites More sharing options...
Wobby Posted May 19, 2005 Report Share Posted May 19, 2005 Ahh, ok. Thanks Can i do any damage trying it?? Thanks RobK Link to comment Share on other sites More sharing options...
Paul Posted May 19, 2005 Report Share Posted May 19, 2005 http://www.ross-tech.com/vag-com/cars/passatb5.html Link to comment Share on other sites More sharing options...
Wobby Posted May 19, 2005 Report Share Posted May 19, 2005 Cheers Nothing about the speed sensing lock on there, i better leave it alone, just wondered if you had tried it on your mates. If its fairly safe and i could reset back to original code then i would have given it a try. Thanks for the advice RobK Link to comment Share on other sites More sharing options...
