How to program a VW Key fob remote
deepi
I just bought a second hand remote key fob for my golf mk4 from ebay, got the blade cut from the guy on ebay and inserted it into the fob.
Only thing now is to program it. Any ideas? (VW want about £50 to do it).
I noticed the VAG COM software does the key matching, anyone know any garages in manchester that have it?
One interesting thing is, if i start my car with my normal key, and then with the new key fob it works fine
thats wack, i cannot belive that theres no store that have that VAG COM software who can do the job, i tried a few garages with the diagnostic computer, even awesomgti said no.
F vw, i even have to book it in, get the v5 etc...
It's for two reasons.
1. Security, to prevent copy coded key being in the wrong hands. VW will still expect proof of ID and vechicle ownership.
2. To screw you for £70 (well that's the amount VW stealer mentioned to me!
Rotten that you haven't got a choice, but then sort of prudent regarding the cars being stolen via a 3rd party with a coded key.
No, the transducer / transponder thingy is fixed only in the car.
The key re-prog only sets up a handshake. So keys cannot be set to any code other than the one set in car, if you want to start it!
I see you point, but in today's world VW being the only authorised new key setting up point prevents scum from walking in to VW and saying my reg and then getting away with my R32.
Sorry mate, I do not see that being tight and whinging about a security item on a car that can cost up to £24k is valid. Just go down there pay it and don't feck up the key again!
I don't dispute that it's a rip off, a new key plus coding is £145 IIRC which is taking the p155, but hey ho, if it prevent scum, then I'll pay it!
  • 6 years later...
Yes found it, and it didnt work
I had a similar problem with my 2009 VW Fox. My remote key stopped working for some unexplained reason. I opened the car manually and started the engine. Then I pressed the LOCK button twice. If you are successful in programming the key, then the car locks should automatically engage after pressing the lock button twice as described.
I am not sure if this simple method would work for older VW models.
  • 1 year later...
Hello guys! i know it has been a while since this thread was posted.. i was just browsing for the same reason and yesterdai i found this step by step instruction that might still help those who are looking for the same answer..
to reprogram you keys you can follow this:
[h=1][/h]1997 or later
  1. Switch Ignition On and leave the key in the ignition
  2. Lock the vehicle by using a manual key from driver’s door
  3. Using he remote fob, press the unlock button – this should make the horn sound once
  4. Wait for 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
  5. Switch ignition off
  6. Remove key from ignition and check for operation
  7. The coding procedure can be repeated up to 4 times for additional remotes
  8. The ignition must be switched off between programming each remote control
Remote control erasing
1997 or later
  1. Switch ignition on and leave the key in the ignition
  3. Press he remote control lock button 5 times within 1 second intervals. The horn should sound or the indicators flash
  4. After 6 seconds press the unlock button once to activate memory erase
Remote control Synchronisation
  1. Open the car using the driver’s door
  2. Press the remote control unlock button
  3. Put the key into the ignition and switch it on
  4. Switch the ignition off and remove the key
  5. Press a button on the remote control
Source: Volkswagen
cheers mates!
Edited by shao_khan
  • 2 months later...
Just to confirm this just worked for my wife's 2007 Fox Urban.
Thought the batteries were dead, took them out noticed top one was corroded, rubbed it a bit, put it back in and pressed the buttons and the LED lit up with each push. But wouldn't unlock the doors. Used the key to open the door, turned on the ignition, pressed lock twice and BAM, all good. Cheers!
Sai
