Soft Top Closure
audijc
Hi there
I am new to this group and haven't had my A4 Cabriolet for long.
Could anyone tell me if there is a way of closing the Soft Top using the remote key.
My car is a 2004 Audi Cabriolet 3 Litre UK Spec if that helps.
The car isn't coded to close the roof with the remote control, but you can close by inserting the key in the drivers door lock and holding it in the lock direction..this will close the roof fully..i'm pretty sure you can open it in the same way.
A colleauge of mine has coded an A4 cab to close the roof with the remote, but i've not tried it myself.
By the way, has your cab got cruise control????..send me a PM if it hasn't 169144-ok.gif
You can open and close the roof from outside of the car with a "double twist" of the key in the door lock.
Basically, to lower the roof twist the key fully towrd the unlock position, release it then immediately twist it over again but this time hold it over. If you let go the roof stops, although another double twist and hold continues the motion.
Do the reverse (ie toward the lock position) to raise the roof from outside.
A single twist will just raise or lower the windows. (Which means once the roof is down a single twist toward the "unlock" position and hold will drop the windows for you).
Hope that makes sense and welcome to the finest Audi Cabriolet forum on the net! 169144-ok.gif
Thanx for your reply stratty31, i have tried opening and closing the roof using the key in the lock and that seems to work fine.
I was hoping to be able to do it by the remote key as i am a disabled driver who uses a wheelchair and it would be useful to operate it remotely.
You mentioned a friend that had it enabled on his, is this easy to do and does it invalidate the warranty.
In answer to your question yes i do have cruise control.
Hang on, coded ??
Are you saying it can be done without hardware mods ?
There are a whole lot of people here who'd <u>love</u> (/kill) to know how to do that - you can't just make a comment like that and leave it hanging !! EEK2.GIF
And if it is possible and you do find out how he did it, please publish it - none of this secretive pm'ing stuff NONO3.GIF
Ross-Tech's site says :
<font class="small">Code:</font><hr /><pre>State Bit Dec. Function
ON 0 1 windows up with remote
ON 1 2 windows down with remote
ON 2 4 windows up with key in lock
ON 3 8 windows down with key in lock
ON 4 16 sunroof close with remote
OFF 5 32 sunroof open with remote (does not appear to work)
ON 6 64 sunroof close with key in lock
OFF 7 128 sunroof open with key in lock (does not appear to work)
</pre><hr />
Nothing about cabs'
It has been done, I've seen it!..with NO extra software added.
I tried it on a Cab last week, but it had a roof fault so I think that's why it didn't work.
If you can all be patient, I'm sure I'll attend one this week and I'll have a play and let you know...alternativly, is anyone close to Swindon???..come and see me and we can have a play...there won't be a problem if it won't work as we can always put it back to how it was 169144-ok.gif
But at nearly 30 seconds each way, how long do you suppose the key fob battery will last...? crazy.gif
God switchblades still not recharge in the ignition? BMW ignition keys have been doing this for a while now as far as I was aware. Oh, hang on, sorry, wait a minute. This would mean Audi Stealerships will not be able to rape the customer for a battery change. How stupid of me. 'That will be one hundred pounds please Mr Clarke.'
Ian
I think I'm getting there but need Stratty's assistance to get further.
I've recoded the module to 7915 which on a saloon/avant gives you the comfort functions with remote (+64).
I've then changed Adaptation Channel 62 from 204 to 207.
204 gives the following:
windows up/down with key in lock
sunroof close/open with key in lock
207 gives the following:
windows up/down with remote
This half worked, windows would close OK with remote but only opened 2 inches and then they stopped.
I then tried changing channel 62 to code 255.
255 gives the following:
sunroof close/open with remote
No joy at all, windows would open 2 inches again and then nothing.
