Chav Posted July 15, 2005 Report Share Posted July 15, 2005 [ QUOTE ] Ari, it does work, the failure is the system controlling the fan speed. So, very hot day, get into car and switch on engine. Air con comes on, and very cold air immediately comes out, but at the lowest speed setting. If I manually up this to max, it blasts it out. So there is no problem with the air cooling side of things. It's the system not upping the speed at all automatically. If I set the temp to high, warm air comes out, set it to cold, cold air comes out - but all at the lowest possible speed setting (1 led on the power/fan speed meter display). After a short while (approx 10 mins) of crawling through traffic and then onto the motorway it kicks in and we're back to normal again. Does it sound like a fault then? [/ QUOTE ] Have you got it in econ mode? ....Sorry, just checking Link to comment Share on other sites More sharing options...
Sparky Posted July 15, 2005 Author Report Share Posted July 15, 2005 No, not on Econ mode. It's only happended twice. The day before the meet, and yesterday. Both days were scortching outside. It corrected itself and worked perfectly for the rest of the day. Doesn't go wrong in the morning (when it's colder). Link to comment Share on other sites More sharing options...
UBM Posted July 15, 2005 Report Share Posted July 15, 2005 Can you not just take it to your nearest stealer as it is under warranty! Link to comment Share on other sites More sharing options...
Sparky Posted July 15, 2005 Author Report Share Posted July 15, 2005 Yes, but I've moved house now, so would take over an hour. Will have to see what Wakefield Audi is like now. Link to comment Share on other sites More sharing options...
