20 inch or 18 inch Wheels?
AnArtist1
As a general rule, the idea of bigger wheels is to reduce the effects of tyres distorting under cornering. This means that you can usually carry more speed through corners.
The side effect though is that the ride becomes a lot firmer, and can even become jumpy if the wheels are too big. For instance, the TVR T350 comes with 16" wheels as standard, and it performs best with these wheels. However, a lot of people opt for 18" wheels, and the handling actually suffers as a result of too little give in the tyres.
There's a LOT of good information here: http://www.chris-longhurst.com/carbibles/
I'd be interested to know what tyres the 18" and 20" wheels run on. Were cars supplied from the factory with 20" wheels calibrated to a different rolling radius than ones supplied with 18" wheels?
245/35 on my 18" Sport, the ride is firm(ish) but deemed acceptable.
Incidentally I drove and XK8 with 20" rims at the weekend and the ride was surprising good, no crashing through pot-holes - very pleasantly surprised how good it coped with such little rubber.
Wouldn't fancy it at speed through the twisties mind.
I had 18's on mine, running 245/45's the ride was pretty good. I then changed to 20's running 245/35's as this was deemed to be the correct tyre fitting. The ride was a little firmer, but great through the twisties smile.gifECLIPSe.gif
Now my 20's are running 245/40's as this is apparently the OEM tyre size for our mota's. Still playing with the tyre pressures (might be going 40 front 36 back) to get the same feel as I had before. Ride is much smoother than with the 245/35's but still lovely around those lovely twisty roads over our way laugh.gifFIREdevil.gif
