emm3 Posted July 21, 2005 Report Share Posted July 21, 2005 Has anybody got the definitive answer for curing brake squeal on the RS6. When slowing down to a stop from 5mph the car sounds worse than a Blackpool tram, any other time it's ok, just at very low speeds. I am totally embarrassed in traffic. The car is 15 months old and has covered 4500 miles, would this be covered under warranty ? Link to comment Share on other sites More sharing options...
Dave Posted July 21, 2005 Report Share Posted July 21, 2005 I used to get this when i had a stone which had got lodged into the brake pads.. might be worth having a check.. otherwise it might be that you have warped discs , or some other problem Link to comment Share on other sites More sharing options...
Oivind Posted July 21, 2005 Report Share Posted July 21, 2005 This should definitly be covered by the warranty. Link to comment Share on other sites More sharing options...
akira Posted July 21, 2005 Report Share Posted July 21, 2005 Mine were squeeling when the weather was hot, not doing it now. I've mentioned it to the dealer and he said just to keep an eye (or ear) on it. Link to comment Share on other sites More sharing options...
emm3 Posted July 21, 2005 Author Report Share Posted July 21, 2005 I've got the car booked in with the Dealers next Monday, let's see what they come up with Link to comment Share on other sites More sharing options...
Chris_B Posted July 22, 2005 Report Share Posted July 22, 2005 [ QUOTE ] Has anybody got the definitive answer for curing brake squeal on the RS6. [/ QUOTE ] Only aftermarket brakes, sadly. OEM brakes will always end up squealing, especially after the summer warm weather; bad cooling design. Link to comment Share on other sites More sharing options...
emm3 Posted July 22, 2005 Author Report Share Posted July 22, 2005 [ QUOTE ] [ QUOTE ] Has anybody got the definitive answer for curing brake squeal on the RS6. [/ QUOTE ] Only aftermarket brakes, sadly. OEM brakes will always end up squealing, especially after the summer warm weather; bad cooling design. [/ QUOTE ] Presumably a set of different pads wouldn't work then, i.e. green ones ! Your right about the warm weather though, the brakes never seem to play up in the morning, but going home, I do get stuck in stop/start traffic everyday. (and that's when I slip down the seat and hide because everybody puts their hands out thinking I'm a bus ) Link to comment Share on other sites More sharing options...
crasher Posted July 22, 2005 Report Share Posted July 22, 2005 Sorry to barge-in on your forum chaps...just thought i'd chip in... I've got Porsche discs/brakes on the front, and EBC Red's on the rear of my S8, and over the last couple of weeks I have noticed increased squealing, especially when braking from a slow speed. I certainly recall AmD (who did the upgrade) telling me that the EBC's do sqeal, especially in the warm weather, and that this is 'normal' behaviour. Strangely, they did not sqeal when i was still bedding them in, its only now that they've started. So it could well be to do with the weather etc. Just a thought... Cheers Link to comment Share on other sites More sharing options...
emm3 Posted July 29, 2005 Author Report Share Posted July 29, 2005 The Dealer cleaned out all four brake assemblies and the squeal came back after only two days Link to comment Share on other sites More sharing options...
johneroberts Posted August 3, 2005 Report Share Posted August 3, 2005 This is down to the brake composite, suggest you look for a different composite (softer would be better) try Padgid Orange or a standard Porche/Brembo if you can get one to fit Cheers jr Link to comment Share on other sites More sharing options...
