mk4 tdi glow plug warning light
onegolf
I've not heard much about it in the English cars, but the US spec calls for an indicator for when a brake bulb is blown. VW decided to use a flashing glow plug light to indicate this, and I'm not sure if the UK spec ones are the same. It's worth checking your brake lights and making sure they're all working ok. Then it could be the brake switch which is known to be faulty quite a lot of times, but again this depends on the failed bulb indicator system I just detailed. The switch either doesn't turn the brake lights on or they don't go off.
Those are simple things to check, so have a look and get back to us.
Thanks for that - I had been told that I had one brake light out (which I had totally forgotten about) - and when I checked them both bulbs had failed. Seems like the UK spec might include similar to the US. Not sure why the warning wasn't on solidly rather than only some of the time though? Seems to have fixed it - at least haven't had a recurrence yet.
  • 2 weeks later...
I think the glowplug light flashing has something to do with the safety system of the DBW (drive by wire) throttle.
A built in function of the system means that regardless of where the throttle is, if the brakes are put on, the engine cuts to idle. Obviously if the brake lights / switch are out this system is disabled.
  • 1 year later...
If both your brake lights fail, the third one at the top of the rear window should be on all the time as a warning to other drivers.
The glow plug light could have been going on and off like that because the problem with the brake pedal switch was intermittent - that's what it was like when mine went.
