Rust on S3 - really worried!
harminder
OK I hope this post will put my mind at ease a little..
I brought my car around 4 months back..
Everything was fine and then around 6 weeks ago I noticed a small bubble in the paint at the bottom of the rear arch! blush.gif
Got worried and then started looking more closely at the paint and noticed another 2 smaller paint bubbles on the other side of the car in exactly the same place (bottom of rear wheel arch).. shocked.gifshocked.gif
I have also noticed a very minor bubble starting near the roof of my car (in line with bubble on the drivers side rear arch).. dung.gif
Now I understand that Audi have a 10 year anti-corrision warranty but I am pretty sure that this is worthless with audi fobbing me off with some excuse or another.. fekr.gif
I dont think the paint work has been repaired as it looks original and also its strange that both sides of the car have been effected in same place?
Now I am seriously getting worried and I cannot see no easy way out of this... confused.gif
Do I have a case in order to fight Audi, especially with the car being 5 years old and out of warranty?
What steps can I take in order to get Audi to pay out?
Also does anyone know how much the repairs are likely to cost?
Just in limbo at the momment.......I am even considering selling the car and hope no one will notice the rust bubbles? sekret.gif
Just need some help and guidance from you guys?
These anti-corrosion warranties are a nightmare. Mazda offer a similar service, but when I spoke to my dealer about corrosion on my old 323F, no chance was he paying out!
I think that in order to keep the warranty, a log of chips/damage etc should be taken on a plan of the car in order for the warranty to be valid, but I can't remember the last time I saw one of those!!!
Your best bet is to give it a go. There's no harm in asking. Perhaps try a couple of dealers in your area. If you have any receipts/MOT's/service print outs from the previous owner, it may be worth digging them out and giving the garages a call. In theory a main dealer should have a log of any work taken out to each car, in which case any repairs could be on file?
Good luck!!!
I know that audi are going to say that car has had some sort of paint work in the past and so the warranty is not valid..
Even though I know they will be talking shite the problem is I have no way of proving that a paint job has not been carried out.. sportifs2.gif
I will try them and let you know what they say..
We once got a door and bonnet replaced on a Fiat Panda - all under the anti-corrosion warranty. Didn't stop it rusting in other places after the warranty expired, though!
I also had a suspicious blister attended to on my RS6 - it turned out not to be corrosion, but contamination under the paint. However, the whole tailgate was resprayed.
I would have no hesitation - get the car in to your dealer and insist that they sort it.
Two people came out and one said straight away that the bubbles appearing on the bottom of the rear passenger arch were caused by stone chips.. blush.gif
She reckons that stone chips have caused the paint to come off slightly and thus allowing water to get in and hence the bubbles..
Same issue on the other side...
OK I thought...........they may even me right (since each bubble does have a slight pin point dot where the paint appears to have come off)..
Well then, I said, that may explain the bubbles at the bottom but what about the one in roof....(just along the grove where a a roof rack would fit in?).. FIREdevil.gif
They basically had no explanation for that one.......that could not be stone chips! He then went along the lines of a paint job being done.........but then later admitted this was very unlikely or the job would have been top notch!
In the end they both tried to fob me off by saying that I should see how I get on over the winter in more harsh conditions and too keep an eye on it!! SAUER0421.GIF
Just wandering if perhaps the bubbles are caused by contamination rather than corrision......would this be an easier fix?? confused.gif
sorry just dont accept that , you would 'see a stone chip' and it would have to be to bare metal to cause it, go back and say you have been talking to audi uk and that it should be honoured... keep trying they are just trying not to fork out on the work.. if not just go to 10 other dealers , someone will fix it ! dont worry+++
..it would have to be to bare metal to cause it,
... and it would have to have damaged the galvanised surface.
Even had the guy from Chipsaway have a look and he two agreed that they probably are caused by stone chips but rust should never settle in that easy..!!
OK going to go to another dealer next week now that I have some come back to the stone chips excuse...!
If anyone has any further responses to excuses they may use then would be most appreciated!! 169144-ok.gif
If you want to retain your sanity give up now. I wouldnt wish my paint/corrosion warranty experience on anyone even though they did the rectification work in the end (at a cost of over £6800 to them).
Ian is right they have done a nice job, but it was still a nightmare.
You will find that for them to honour the corrosion warranty the rust has to come from the inside of the car.
In my case the exterior paint surface was intact, 20 different areas on the car including in door shuts, bonnett edge the inner B pillar all without question could not have been stone chips. I had a paint experts report to that effect and Audi still said it was because of stone chips.
The pannels that were eventually sent back to Germany but im never likely to know the exact cause.
To be fair you are probably right, I think it will be a lot of stress for little reward... crazy.gif
Had a quote from Chipsaway to restore the bottom section of both rear wings and then 'blow them in' to match the colour.
The guys seemed to think it would do the trick for the time being but was honest to say that he could not be 100% sure it would cure the problem in the long term!!
Gave me an honest price and said he would take care of all the chip marks to the front of the car.....prevent any further possibilities of rust setting in.. sportifs2.gif
Someone convince me its worth holding onto the car becuase in the long term these issues are only going to get worse?? SAUER0421.GIF
Guy reckons to repair the bottom section only of both wings and also to cover a deep scratch on passenger side door (also paint needs blowing over) then he can do it all for £250..
This will also include him sorting out all the stone chips to the front of the car..
Reckons car should look ok and paint should match otherwise he will not charge me for it..
I am tempted but then wondering if in 6 months the bubbles come back will it really have been worth it?? crazy.gif
my experiance of rust on my Golf was to get it cut out 100% or it will come back the following winter, if you are only going to keep the car say 6months go for it , it will mean its unmarked when you sell it , but for the poor bugger that buys it he will have no chance of getting it done form audi , i really would take it down that route , or at least see if they will pay the £250 from chips away as a compromise ?
At the minute the bubbles are not too noticeable (most people would not notice)..
I am going to probably wait a few months and keep a very close eye the areas concerned..
If they get any worst and look like they are spreading quickly then will get it done by Chipsaway..
If on the other hand the bubbles are the same I will prob sell the car as seen.........will not mention it but will not hide it... UHOH7.GIF
Be wary of leaving it and 'keeping an eye on it'..... It might be rusting fom the inside out and you wouldnt see it! Trust me - i have a Starion and i know these things....!!! (if you are silent you can actually hear it rusting.....) grin.gifsmashfreakB.gif
just get audi to sort it , but it should be covered ! how much was the quote from chips away ?
Tom its really not as easy as that, warranty does not cover stone chips, as HH said in a previous post the wings could be chips as there is a bit of paint missing this indicates it proberbly is caused by chips being left untreated.
I'm trying to give the best advice I can and from my experience the chances of Audi repairing the car are about 1% on what Ive read so far.
Its best to get it repaired and the affected areas treated which will give it the best chance possible.
