sportsman Posted September 27, 2005 Report Share Posted September 27, 2005 Does anyone have any experiance of the HID lighting kits just wana know what they are like and is it worth it..Might try to get it done my MKV Link to comment Share on other sites More sharing options...
Rustynuts Posted September 27, 2005 Report Share Posted September 27, 2005 Been discussed here. Link to comment Share on other sites More sharing options...
R32North Posted September 27, 2005 Report Share Posted September 27, 2005 Think he might be talking about the uprated replacement bulbs that use 'Xenon' technoogy to give brighter, whiter light, as opposed to the full on Xenon headlights! Sportsman, can you elaborate ? Link to comment Share on other sites More sharing options...
sportsman Posted September 27, 2005 Author Report Share Posted September 27, 2005 The one that are on here http://www.hids4u.co.uk/default.asp Link to comment Share on other sites More sharing options...
Rustynuts Posted September 28, 2005 Report Share Posted September 28, 2005 Then your car will not be legal to drive. Only OEM equipment with the correct lighting units, headlamp assembly, auto-levelling kit, headlamp washer system will keep you road legal. Putting a HID kit into your standard headlamp will not give the correct lighting pattern or beam, will dazzle other road users (as they won't auto level) and when it comes to MOT time, your car will fail. I know it's a couple of years down the line, but if you do happen to attract the attention of an observant policeman, you're going to be done. Factory fit items (if you can source them) will be expensive, but will keep you legal. Link to comment Share on other sites More sharing options...
R32North Posted September 28, 2005 Report Share Posted September 28, 2005 You can fit the HID bulbs, which cost around £15 ea, and these do improve the lighting quite noticeably. Can't believe that guys is selling those bulbs for that much. If they are true Xenon and he's seeling them to people without the necessary 'other' parts, ie leveling, washers, surely he walking a thin line!! Link to comment Share on other sites More sharing options...
Avus_Bub Posted October 4, 2005 Report Share Posted October 4, 2005 There are plenty of these 'Full on Xenon/HID' kits on Ebay for well under £180. Legal or not that's going to be very tempting to the Chavs - Most dealerships charge £150+ for a 2DR or2DS Xenon bulb!!! BUB Link to comment Share on other sites More sharing options...
peteA3TDI Posted October 5, 2005 Report Share Posted October 5, 2005 [ QUOTE ] Then your car will not be legal to drive. Only OEM equipment with the correct lighting units, headlamp assembly, auto-levelling kit, headlamp washer system will keep you road legal. Putting a HID kit into your standard headlamp will not give the correct lighting pattern or beam, will dazzle other road users (as they won't auto level) and when it comes to MOT time, your car will fail. I know it's a couple of years down the line, but if you do happen to attract the attention of an observant policeman, you're going to be done. Factory fit items (if you can source them) will be expensive, but will keep you legal. [/ QUOTE ] HID kits will give you the correct beam image (just fitted a set and checked)and are not a mot fail, headlamp washers and auto level are not part/tested on a mot so cannot fail but you can still get done by the old bill if they know about having to have washers and auto level fitted Link to comment Share on other sites More sharing options...
R32North Posted October 5, 2005 Report Share Posted October 5, 2005 [ QUOTE ] [ QUOTE ] Then your car will not be legal to drive. Only OEM equipment with the correct lighting units, headlamp assembly, auto-levelling kit, headlamp washer system will keep you road legal. Putting a HID kit into your standard headlamp will not give the correct lighting pattern or beam, will dazzle other road users (as they won't auto level) and when it comes to MOT time, your car will fail. I know it's a couple of years down the line, but if you do happen to attract the attention of an observant policeman, you're going to be done. Factory fit items (if you can source them) will be expensive, but will keep you legal. [/ QUOTE ] HID kits will give you the correct beam image (just fitted a set and checked)and are not a mot fail, headlamp washers and auto level are not part/tested on a mot so cannot fail but you can still get done by the old bill if they know about having to have washers and auto level fitted [/ QUOTE ] Regardless of MOT's etc its still illegal and will invalidate your insurnace quick sharp. These days any excuse to not pay out a claim, on either parties' insurance, is at the top of any insurers list so even if you declare that you've added this 'mod' to your car your insurance will be invalid as you don't have the necssary components to go with it. If you fitted the bulbs to the existing headlight housing then you will NOT have the correct light pattern, as HID / Xenons have a different focal length than standard lights, yes it may well look like they are producing the correct beam but that is a beam for non-Xenon bulb. Its each person perrogative to do what they like, ie fit such a kit, I'm simply stating a few facts that people should be aware of!! Link to comment Share on other sites More sharing options...
