Braytak Posted May 24, 2003 Report Share Posted May 24, 2003 Hi Guys. Anyone given any thought to keeping the roof of your Cabriolets in fine fettle. I have noticed a few products on the shelves, 'two bottle solutions'etc. Has anyone got any recommendations or experience of using such products. Cheers. Gez.... Link to comment Share on other sites More sharing options...
Braytak Posted May 24, 2003 Author Report Share Posted May 24, 2003 Oh Go on then! I'll get me top down......... Link to comment Share on other sites More sharing options...
Ari Posted May 24, 2003 Report Share Posted May 24, 2003 Well since it has been branded a hairdressers car... Take two bottles into the car wash? Not likely, i just "Wash And Go"! Err... anyway moving swiftly on! I just use the Autoglym shampoo stuff I wash the rest of the car with. I give the hood a good soaking with the hose first, then wash it with the sponge and soapy warm water (going from front to back following the grain of the hood as recommended in the owners manual) then hose it off afterwards. Still looks good as new so far. Have heard other people hoover theirs (seriously!), but not sure how I'd get the Dyson up there! Link to comment Share on other sites More sharing options...
Newbie123 Posted May 24, 2003 Report Share Posted May 24, 2003 Ari, you shouldn't really use any car shampoos on the hood because of the waxes etc that they contain. Well thats what I was told anyway. I think the handbook, from memory, recommends that you clean the hood just using a brush and water for everyday cleaning. You can purchase some Audi cabriolet roof cleaner from the dealers to remove stubborn dirt and also to give it an all over clean every few months. Link to comment Share on other sites More sharing options...
Ari Posted May 24, 2003 Report Share Posted May 24, 2003 [ QUOTE ] Ari, you shouldn't really use any car shampoos on the hood because of the waxes etc that they contain. Well thats what I was told anyway. [/ QUOTE ] Oops! Have to say, the roof is quite amazing in it's water repellency. It is actually quite hard to wash it conventionally as the water just seems to run off without touching it. Guess I'll have to get a brush thingy then. Any idea where you get them? Got some Audi hood cleaner but not tried it yet as current (probably wrong) method seems to keep it good. Link to comment Share on other sites More sharing options...
jeff Posted May 30, 2003 Report Share Posted May 30, 2003 When I first washed my roof I used a cotton-covered sponge---huge mistake, the roof fabric pulled a massive amount of lint from the cotton surface. Since then I have had much better luck using the following approaches: 1. Use a microfiber mitt when washing (just water works fine). It won't shed lint and will pull dirt from the top. 2. For a dry touch-up, use a microfiber towel or one of those lint brushes (see below). It picks out seeds pretty well (we have cottonwood trees which can cover nearly every square inch nearby with cottony seeds). I keep one in a storage bin in my Cab. By the way, if you're really into keeping your car clean. A daily touch up with a California Car Duster (also see below) works great, although your neighbors will think you're wacky when they see you dust-mopping your car. Link to comment Share on other sites More sharing options...
CARACTERE 007 Posted May 31, 2003 Report Share Posted May 31, 2003 wow that car looks very very clean!!!!...is that zaino? Link to comment Share on other sites More sharing options...
Keegs Posted June 2, 2003 Report Share Posted June 2, 2003 I have some roof care product from Audi, never used it, has anyone tried it??? Link to comment Share on other sites More sharing options...
jeff Posted June 2, 2003 Report Share Posted June 2, 2003 Caractere 007, quite an eye you've got; that is Zaino on my Cab . More on the top cleaning issue, I happened to run across a thread in Autpoia.org discussing convertible top care. I emailed the customer service at Wolfsteins Pro Series. His reply was: RAGGTOPP products have been tested and endorsed by The Haartz Corporation (OEM) the world's leading manufacturer of convertible topping for virtually every American and European convertible including the Audi TT Roadster, Audi 80 Cabriolet and your Audi A4. What left the factory when your [car] was manufactured is what you are putting back on it. [sic] Our new RAGGTOPP Vinyl Protectant that contains NO SILICONE or SOLVENTS. Our patented formula contain Ciba Tinnuvin 5151 UV blocker that protects interior and exterior appointments against fading and cracking. You want to purchase the RAGGTOPP Convertible Top Care Kit containing our RAGGTOPP Cleaner and RAGGTOPP Fabric Protectant. (attached cleaning instructions) RAGGTOPP The First Convertible Top Cleaning and Protection System HOW TO APPLY RAGGTOPP Fabric/Vinyl Cleaner * Wet Convertible Top thoroughly. * Spray and apply evenly over entire roof and scrub lightly with soft nylon brush. * For very difficult soiled areas, spray and let stand for 15 to 20 minutes. Scrub lightly with soft nylon brush. * Rinse thoroughly with water until no remaining soap foam is observed. IMPORTANT: CONVERTIBLE TOP MUST BE THROUGHLY DRY BEFORE USING RAGGTOPP FABRIC PROTECTANT RAGGTOPP Fabric Protectant FABRIC TOPS * Start with a clean dry convertible top. * Shake well before use and several times during spraying. * Hold can upright and spray evenly 12-14 inches from material. * Spray three light even coats of RAGGTOPP Protectant using gentle sweeping motion. DO NOT SATURATE. * Allow to dry 10 minutes between coats in the sun. Artificial heat can be used to speed drying time. USE A CLEAN COTTON TOWEL/RAG or MICRO FIBER TOWEL TO WIPE OFF ANY OVER SPRAY I'm planning on ordering some to give it a try. I'll post my results afterward. Happy cruising! Link to comment Share on other sites More sharing options...
