282 bhp!!
RedRobin
280hp = faster acceleration, which means objects get closer quicker, which means that given the same reactiom time you'll need to stop quicker - hence better brakes!
Also, the suspension is an integral part of how the power is transmitted to the road. More power will mean more stress on the suspension.... oh, suspension is more than just damepers and springs, its bushes, links, roll bars, wishbones, etc, and I'm taling about it all.
With all that power you'll want to be able to control the car better, keep it flatter to the road and less likely to step out, so uprated damerps / springs, bigger ARBs, hardened bushes, etc are required to improve all aspects of power transmission and road holding.
But in a nutsheel - you don't opt to have 280hp and then drive it the same as when it had 200hp. You will drive faster, brake later, enter corners at higher speed and try and exit them at greater speed as well... all of which means you'll push the stock set-up to the limit and beyond, so YES you will need to upgrade brakes and suspension for those very reasons!
I've been driving cars for 15 years, tweaking them, modding them, pulling them apart and rebuilding them and one thing that has always stood the test of time is that when you up the power by a large amount, without fail you do the brakes and suspension or ultimately you will pay the price.
I would value your advice whether you think that the GTI would be within sensible and safe limits (in the way you describe in your post) to upgrade to 220 bhp without further suspension/brake etc mods.
Many Thanks,
Aye, 220 / 225 would be fine maybe even 230hp with standard parts.... thats only a 10-12% hike in power, but start to creep towards 280hp and you have a totally different car on your hands.
The pressures and forces being applied - think of all that power / torque be transferred to the drive shafts and tyres, while the engine and transmission are being held in place by the mounts, and the wheels / tyres are directly connect to the struts - are much greater and so beefed up parts are required otherwise shortened life spans of std parts is to be expected!
Most importantly are the driving and handling characteristics of the car - no way will 280hp be the same as 200hp. Different beast althogether!!
I've only had the ~6463 remap, filter and exhaust and reckon about 255hp / 260hp. If I were to go above 280hp, ie cams upgrade, even with the R32 having massvive brakes I'd upgrade. I'd also change the ARBs and possibly the struts / springs, even tho they are Bilstien / H&R.
Also, don't think for a minute that VW parts are up the job when talking about big power hike like that - mounts, bushes, links, etc will go pop
Robin, you could comfortably uprate the GTI to 250 bhp without needing to uprate your brakes as well, but you would be pushing it!
The cost of uprating the anti-roll bars is relatively small compared to uprating the shock absorbers and coils, but the car would definitely benefit from it, even with the stock 200 PS
Also, brake upgrades don't have to mean mega-money. You can spend anything from £500 to £2500 - it all depends how far you want to take the car.
DanAdams - I have to agree with Six - if you uprate your GTI to 220 or 230 bhp, you'll be fine, but when you start getting into the realms of pushing a lot more power, you've got to be able to stop more quickly.
A lot of it does, of course depend on how you drive your car. The R32 brakes, for example, are fine for normal road use, but spend even an hour on a track and they fade too much. The Mk5 GTI brakes are fantastic, but I'm sure they would fade after prolonged use as they do on most road cars when they're driven hard, on the track or "enthusiastically" on the road. 169144-ok.gif
SixDegrees and Mook - 169144-ok.gif That's great and what I hoped to hear. My conclusion is that 220-230 is as much as is sensible for the GTI's durability and driveability on the road without further very physical mods. I expect too that re-mapping isn't just about achieving high bhp numbers but it's also about improving practical efficiency throughout the whole range.
In my opinion, however hard you drive a car it doesn't need to be constantly driven hard and it always needs to be within safe boundaries, in terms of both road conditions and any stresses on car components. In F1, Mercedes-McLaren pushed the envelope and suffered the consequences in reliability.
I agree totally with the comments about the need to upgrade other components, especially brakes, when getting a substantial hike in power. You will be getting up to a higher speed in the same distance and your brakes will be generating more heat to haul you back down again. Do that for a while and you will find you have no brakes
I posted some initial Revo graphs a month or so ago.
It has to be noted that the highest increase gained was on 100 Octane race fuel so I'm guessing the 288bhp quoted was done on that, otherwise it seems excessive!
Here are the original graphs. I'd be happy if I had got 260bhp, I think I will be going down this route at some point. Revo is switchable too so I'll be able to tone it down when the gf drives 169144-ok.gif
I also learnt today that 17s are very efficient and tuning doesn't mean you need bigger wheels. Milltek's 19s on their tuned GTI are purely for aesthetic reasons.
Quite right about the tyres and wheel sizes. Bigger wheels stiffen things up, but also can provide less feel when driving on the limit compared to a smaller wheel with a larger tyre wall.
Granted bigger wheels look better, but for the racetrack smaller wheels and bigger tyres every time! 169144-ok.gif
I think you're comparing going round the track in your Massey Ferguson aren't you Danksy..?! tongue.gif
19" wheels and tyres on a 35 profile provide much more taut handling than 18" wheels with a 40 profile. 19" wheels and tyres and much more difficult to live with for daily driving though.
One of the great things about the Mk5 GTI is that the 18" wheels are the same design as the 17" wheels, so, unless you're an officianado, no-one will notice the difference just looking at the car. 169144-ok.gif
Hi chaps, I'm getting mine remapped soon (same running gear as the Gti but with 4wd wink.gif )and will be looking at the brakes for sure (more weight due to 4wd gubbins). I'm pretty sure the 345x30 setup on the A3 3.2 will go straight on the A3 and Gti. You'd need the discs, back plates, calipers and caliper carriers which work out at approx £400 plus fitting. You'd then have the same setup of an S4 which is more than enough. Perhaps a group buy might be in order...
I've also run a Revo Leon Cupra R running approx 280hp for nearly 3 years and a FWD chasis can handle that sort of power easily if you are sensible with it... ECLIPSe.gif
....And you would be in the car in your avatar? I sometimes go to Absolute Music Solutions in Poole and also occasionally play at an 'open mic' gig at The Blue Boar in Poole but haven't played there for a while cos they tend to be a bit too folky (musically) for my taste.
My GTI is a bit....distinctive....Quads on an Abt rear and a RED plate on a Red car. Flash bugger ain't I....Not chav though! See ya, I hope 169144-ok.gif
