Ferrari f355 GTS tyre wear
jamdel
I dunno if I am stating the obvious but is the tracking etc. set properly? I realise your regular mechanic may have adjusted the tracking but if the camber, castor and KPI are not spot on then adjusting the tracking is pointless. Get it down to a specialist aligner.
Also remember that even if your front end alignment is perfect, if your tyres are worn on the inner edge, they will still wear there faster after any adjustment. Best buy new ones when you get everything set up.
