aymski86 Posted January 4, 2006 Report Share Posted January 4, 2006 Ok so i have the sweet audi navi plus rns-e system in my a3, but when i try put mp3s on my sd cards i jus get corrupt data and when i put them back in the pc my card is corrupted and i cant use it again, tried formatting and jus wont let me. anyway i jus wana know exacctly what i need to do in order for them 2 work. i download my mp3s of newsgroups so the all have mixed tags etc, which prog is best to used and what filters should i be using with them....a step by spep beginners guide would be mcuh appreciated as the owners manual tells u feck all!!! thanks in advance Link to comment Share on other sites More sharing options...
gizze Posted January 4, 2006 Report Share Posted January 4, 2006 Just format it as FAT and drag the mp3s you want onto the card. You can drag folders with the mp3's onto the card too if you like. That is all there is to it. Link to comment Share on other sites More sharing options...
PetrolDave Posted January 4, 2006 Report Share Posted January 4, 2006 The RNS-E is a bit fussier than DOS or Windows about filenames, e.g. you cannot use the pling (!) character in filenames on the RNS-E. I do exactly the same as gIzzE - drag and drop the folders containing the MP3 files onto the SD card. I also use playlists created using Playlist Creator 3 from oddgravity, so I can choose what gets displayed on the DIS. Link to comment Share on other sites More sharing options...
edo Posted January 13, 2006 Report Share Posted January 13, 2006 is there a limit to card size/amount of data the unit can recognise? Link to comment Share on other sites More sharing options...
PetrolDave Posted January 13, 2006 Report Share Posted January 13, 2006 There's a limit of 512 files/folders. If there are more than that on the SD card, then the RNS-E will only see the first 512. I know of several people, including me, who are using 4GB SD cards, which AFAIK are the largest SD cards available at the moment. Link to comment Share on other sites More sharing options...
edo Posted January 13, 2006 Report Share Posted January 13, 2006 Thanks. 4's still seem a lot more (than double) the price of 2's, so I may stick with a 2gb. Can't be arsed with faffing about wiaitng for it to come from Hong Kong/USA via ebay - any suggestions on the best place to go? Link to comment Share on other sites More sharing options...
PetrolDave Posted January 13, 2006 Report Share Posted January 13, 2006 I got my 1GB cards from Amazon, and a 2GB card for my brother's Navman from Amazon also - I got my 4GB card from eBay for £167. I always go for the hi-speed cards, my RNS-E (and several other people's too) won't work reliably with "normal" cards. Having said that, some people are using "normal" cards without problem. Make your own choice ... Link to comment Share on other sites More sharing options...
edo Posted January 13, 2006 Report Share Posted January 13, 2006 Cool. Thanks. Have found what looks like a reputable seller on ebay who is in the uk. Got a Scandisk 2Gb for £80 all in delivered.. System being fitted by Craig tomorrow, so will let you all know how I get on. Ed Link to comment Share on other sites More sharing options...
mawd Posted May 10, 2006 Report Share Posted May 10, 2006 Hope ist ok bumping an old thread but could anyone advise me how playlists work on the SD cards on RNS-E ? I've downloaded 'Playlist Creator 3' and can add files in to it and create one of two types of files, ,M3U and .PLS. Dont know if this is right but would i open this software and then add the MP3's from the SD card and then save the resulting M3U/PLS file to the root of the SD card ? I'm also struggling with the concept of adding albums to the SD card. I've been told that the RNS-E only displays the first 8 characters of the file name but i've seen pictures on RNS-E units with more information displayed such as Artist -- Trackname (ie Tag information) ? Also, if i creatae a folder on the SD card called 'Stone Roses' with all the MP3's in it does it pick up the folder name as the album name ? Am baffled by all this at the moment hopefulyl all will become clear when i get the RNS-E and can have a playaround with an SD card in it. Cheers , Al. Link to comment Share on other sites More sharing options...
