BenjaminTDI Posted January 20, 2006 Report Share Posted January 20, 2006 As many of you know it is possible to retrofit the ambient lighting in the front of the A4 which is usually only available as part of the interior light pack. This is a VERY EASY mod to do. It is just 2 LEDs available from the dealer. Since Nelson told me about this mod, I have had the parts on order from the dealers. Since there is no guide in english with pictures on how to do this modification I will try and explain as best I can on how to do it in a relatively painless manner. It only took me 30 minutes, and it cost under 10 quid for the parts. There is no wiring involved, the connectors are already there to plug the LEDs in. Make sure you have the following before you begin: The LEDs from your dealer, Part Number: 8E0919063A A drill with a 5mm bit A + screwdriver I apologise for the blurry pics, but they are fine for these purposes. The part: Step 1.) Carefully unclip the two removable panels on your light cluster, in the following order: Step 2.) Locate the two screws in the light cluster that are preventing it from coming out, and unscrew them both - make sure you have a hand ready to catch the screws otherwise you'll do what I did and nearly lose them down the side of the seats. Step 3.) Pull out the light cluster, it should come out very easily. Locate the two spade connectors, it's quite hard to see them in this pic but once you have done the above steps you won't miss them. Step 4.) Clip the part you bought from the dealers in. There is only one way it will go in so dont worry about clipping it back to front. Step 5.) Connect the LED to the spade connectors, be patient and careful with them, they can be quite fiddley. Step 6.) Get your drill ready, and put the 5mm drill bit in. Find terrorist balaclava and put on if you wish to jump out with a drill and scare your wife/girlfriend/mother. (unfortunately I didn't have this privledge as my gf was at work today, ffs). Step 7.) Drill 2 holes in the light cluster you removed, there are circles that protrude the surface and this is where you need to drill. I managed to go a little off center with my first one - don't panic if this happens, just dont deviate too much from the center and you should still be ok. Step 8.) Put the light cluster back in its place and screw it in. Step 9.) Replace all the other bits you took off, and check the mod is working by putting the cars lights on. Step 10.) Wait anxiously until dusk! Then enjoy I hope this is helpful and easy to follow. Many thanks for Nelson for making me aware of the mod in the first place I will post some pics of what it looks like when it gets dark. Link to comment Share on other sites More sharing options...
Soapsuds Posted January 20, 2006 Report Share Posted January 20, 2006 [ QUOTE ] Find terrorist balaclava and put on if you wish to jump out with a drill and scare your wife/girlfriend/mother. (unfortunately I didn't have this privledge as my gf was at work today, ffs). [/ QUOTE ] absolute classic!!! Nice one - cheers for the guide! Am hoping to order this tomorrow and fit it before the next Chavshire meet! Well done matey - look forward to the night pics! Link to comment Share on other sites More sharing options...
Redavant Posted January 20, 2006 Report Share Posted January 20, 2006 [ QUOTE ] [ QUOTE ] Find terrorist balaclava and put on if you wish to jump out with a drill and scare your wife/girlfriend/mother. (unfortunately I didn't have this privledge as my gf was at work today, ffs). [/ QUOTE ] PMSL You really don't see enough terrorist balaclava's in How To Guides!!! Genius Link to comment Share on other sites More sharing options...
Durrsaku Posted January 20, 2006 Report Share Posted January 20, 2006 Nice one. Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 20, 2006 Author Report Share Posted January 20, 2006 If anyone is having trouble downloading the step 5 pic it can also be found here (edit time expired) http://tinypic.com/m98z7p.jpg Imageshack are being useless today so I had to edit and rehost the pics at tinypic.com. I just got to step 5 and the edit time expired Link to comment Share on other sites More sharing options...
Durrsaku Posted January 20, 2006 Report Share Posted January 20, 2006 Some people are just so slow. Link to comment Share on other sites More sharing options...
Chav Posted January 20, 2006 Report Share Posted January 20, 2006 [ QUOTE ] If anyone is having trouble downloading the step 5 pic it can also be found here (edit time expired) http://tinypic.com/m98z7p.jpg Imageshack are being useless today so I had to edit and rehost the pics at tinypic.com. I just got to step 5 and the edit time expired [/ QUOTE ] Why not just upload the pictures to TSN? Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 20, 2006 Report Share Posted January 20, 2006 Very good write up Just one thing though; you've drilled the holes in the light panel too small. You need a drill bit that will fit exactly into that 'crevace' (I think its a 7 mil drill bit IIRC) Otherwise, perfect Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 20, 2006 Author Report Share Posted January 20, 2006 Are you sure nelson? I am sure you said before it was 5mm. Any bigger I reckon they would look gaping. Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 20, 2006 Report Share Posted January 20, 2006 Yup, very sure; I made the mistake first time of only drilling to the first markers. Then I saw an A3 with interior light pack in our showroom and realised they were meant to be ALLOT bigger! Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 20, 2006 Author Report Share Posted January 20, 2006 [ QUOTE ] Yup, very sure; I made the mistake first time of only drilling to the first markers. Then I saw an A3 with interior light pack in our showroom and realised they were meant to be ALLOT bigger! [/ QUOTE ] Ok mate, I guess it makes a difference with how the light is projected if the holes aren't big enough? I will sort this out a bit later Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 20, 2006 Report Share Posted January 20, 2006 Yeah, its allot more BLING when the holes are bigger Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 20, 2006 Author Report Share Posted January 20, 2006 [ QUOTE ] Yeah, its allot more BLING when the holes are bigger [/ QUOTE ] OK I just re-drilled the holes with a 7MM bit - it is definately better with the bigger holes - cheers again mate! Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 20, 2006 Author Report Share Posted January 20, 2006 I've just tried to take some pics of how the install looks at night, but my camera is so it won't capture the ambient lighting properly. If anyone has got a decent camera and has performed the mod post some pics up Link to comment Share on other sites More sharing options...
Avus_Bub Posted January 20, 2006 Report Share Posted January 20, 2006 [ QUOTE ] If anyone has got a decent camera and has performed the mod post some pics up [/ QUOTE ] Will do - After I've fitted my Bub Special rear LED's Pic's to follow BUB Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 20, 2006 Author Report Share Posted January 20, 2006 [ QUOTE ] [ QUOTE ] If anyone has got a decent camera and has performed the mod post some pics up [/ QUOTE ] Will do - After I've fitted my Bub Special rear LED's Pic's to follow BUB [/ QUOTE ] That's so bub special about them, do they project avus silver light? Link to comment Share on other sites More sharing options...
Avus_Bub Posted January 20, 2006 Report Share Posted January 20, 2006 [ QUOTE ] That's so bub special about them, do they project avus silver light? [/ QUOTE ] No - Just red I hope.... They're gonna be special because if I pull my finger out I'll be the first one here to fit them!! BUB Link to comment Share on other sites More sharing options...
Sponge Posted January 21, 2006 Report Share Posted January 21, 2006 I am soooooo going to order that part tomorrow! Link to comment Share on other sites More sharing options...
hashluck Posted January 21, 2006 Report Share Posted January 21, 2006 Please add this to the essential guide! How to save £145 Link to comment Share on other sites More sharing options...
Sponge Posted January 21, 2006 Report Share Posted January 21, 2006 Just called Liverpool Audi and they don't have the part in stock. They can't order it today, apparently, but asked me to call back Monday. They confirmed the price at £8.46 + VAT. Link to comment Share on other sites More sharing options...
BenjaminTDI Posted January 21, 2006 Author Report Share Posted January 21, 2006 [ QUOTE ] Just called Liverpool Audi and they don't have the part in stock. They can't order it today, apparently, but asked me to call back Monday. They confirmed the price at £8.46 + VAT. [/ QUOTE ] Don't be surprised if it takes them a while to get the part in stock, it took my dealer about 3 weeks. Link to comment Share on other sites More sharing options...
harddrive Posted January 22, 2006 Report Share Posted January 22, 2006 I will try and take some this week of the ambient light working. Is there a massive difference with the holes being 7mm in size? Link to comment Share on other sites More sharing options...
harddrive Posted January 22, 2006 Report Share Posted January 22, 2006 Just found this pic on the net which shows the holes being bigger with the LED's behind. I will re-drill mine tomorrow. Link to comment Share on other sites More sharing options...
Sponge Posted January 23, 2006 Report Share Posted January 23, 2006 I just called Liverpool Audi and they wouldn't let me order them over the phone. In fact, they were very abrupt and keen to know why I wanted them. They said I had to go to them in person and pay for the item at time of order. I offered to pay over the phone and reminded them it was only £10 or so, but they weren't interested. Apparently, they had £4500 fraudulent order just before Christmas. Link to comment Share on other sites More sharing options...
wyliss Posted January 23, 2006 Report Share Posted January 23, 2006 Thats spot on....thanks for passing the info on. I wonder what other bits are available that we can fit so easily? Link to comment Share on other sites More sharing options...
