VW Passat V6 TDi Service Questions
Subzero
Hi ALL,
Its time to service my new (to me anyway) 2001 2.5 V6 Tdi passat.
Its done just over 120000 miles and i think it needs a service, as it does not have a full VW history i am gonna do it my self(with help from friends + a ramp smile.gif )
I have a few questions about engine oil type, what would be the best choice for this car? I tend to do only short trips most of the time.
Would it be best to use a fully Synthetic type ? or semi Synthetic?
I have been looking @ the durablend stuff as i read someone one here used it in a 130PD.
Also and recomends on gear box oil ? should i check and top up or replace the current oil? (6 speed manual).
Could anyone also recomend that i use a K&N Pannel filter insted of a paper one? , just i read quite a few good things about them, is it really worth £50 ish quid compaird to £10-£15 for a paper.
Thanks
The service you should carry out is a major,
Air filter (i would stick to a normal filter)
Oil (I would recommend 5w30 semi synthetic)
Oil filter
Diesel Filter (you must fill the diesel filter with fresh diesel before fitting due to the self bleed system being poor)
Gear box oil is EP 75/90
