Webasto Hot Shot
BlackSheep
Yeah I think you can retro fit the heated washer jets. I know someone who fitted it to a Passat and Golf. AFAIK its just a matter of getting a couple of parts and installing them .A local VW Parts Dept should be able to help you out failing that I can look up ETKA for you
JD
I have the heated washer jets and they didn't help the other day when the temperature was -5c.
I had plenty of concentrate in my bottle and the funny thing was the washer jets on the lights worked fine.
I ended up hitting the washer 5 times to activate the headlight washers, the overpspray was enough to hit the windscreen. But the windscreen washer jets still hadn't defrosted by the time I got to work.
may be a silly question but....Is there a risk that this might crack the windscreen in extreme cold conditions, like the UK?
Shouldn't do. I would imagine that the water that comes out is lukewarm at best. My heated washer jets on my MKIV certainly don't warm the water much wink.gif
I guess the 60c feature is probably an overstatement.
