cmcintee Posted February 7, 2006 Report Share Posted February 7, 2006 Having a small intermittant problem when locking my 1998 Golf Mrk 4 1.9 TDI. The car locks ok but when I return the key to the 12 o'clock position to remove the key it sometimes unlocks again. A couple of goes usually locks it, although worried it won't lock one of these days! Also noticed when it is locked that the LED at the drivers side push button sometimes doesn't flash. Any ideas on this? Will I need a replacement lock ? Is the LED just cosmetic? Thanks. Link to comment Share on other sites More sharing options...
pritesh Posted February 8, 2006 Report Share Posted February 8, 2006 The LED is an indication of the alarm being active (i think). what you describe is not unheard of...did you search the site..as this has defs been talk about before? It could be a lock mechanism being dodgey, damaged, possibly the wiring loom maybe broken between the door and the body. Welcome to TSN Link to comment Share on other sites More sharing options...
