compbuild Posted March 30, 2006 Report Share Posted March 30, 2006 Hi guys, The glow plug warning light has just started falshing on my wifes bora, do the plugs need replaced or could this be indicating some other fault, Thanks Link to comment Share on other sites More sharing options...
benjie Posted March 30, 2006 Report Share Posted March 30, 2006 The glow lug warning light on a diesel mis the engine management light. Try starting the car, get your wife to put her foot on the brake pedal and see if the rear brake lights are working. f not, that's what's causing the warning light - a broken brake pedal switch. not much from a dealer, depending on type about £14. Is that's not the problem, the best thing to do is get it hooked up to a VAG-COM - a computer program similar to that of the dealers that many members (including me) own. they can read the car's computer and find out why it's got the warning up. Link to comment Share on other sites More sharing options...
compbuild Posted April 4, 2006 Author Report Share Posted April 4, 2006 Thanks a lot Benjie Yep, that is the problem, cant these be replaced DIY, and if I do that will the light reset itself or will it keep displaying a fault? Link to comment Share on other sites More sharing options...
sotty Posted April 4, 2006 Report Share Posted April 4, 2006 same happened in my golf a few months back. Replaced back light bulb and hey presto no more flashing glow plug light. Link to comment Share on other sites More sharing options...
benjie Posted April 4, 2006 Report Share Posted April 4, 2006 Apparently it's easy to do yourself, but I chickened out and had my vw specialist do it when he did the service (my prob lem was only intermittent) You have to make sure you get the switch fully extended or something!! Link to comment Share on other sites More sharing options...
adamski74 Posted May 22, 2010 Report Share Posted May 22, 2010 did the car go in to safe mode with this fault? Link to comment Share on other sites More sharing options...
