Ari Posted April 4, 2006 Report Share Posted April 4, 2006 What are they and why? Just cropped up in conversation recently and I wondered what they do. (I believe they are something to do with the suspension). Link to comment Share on other sites More sharing options...
DanRS Posted April 7, 2006 Report Share Posted April 7, 2006 IIRC Drop links connect the Anti roll bar, to the suspension, depending on the type fitted they will reduce the amount of roll during cornering... Cheers XFS Link to comment Share on other sites More sharing options...
Ari Posted April 10, 2006 Author Report Share Posted April 10, 2006 Ah, rightio thanks. Does that make the car more twitchy though? Link to comment Share on other sites More sharing options...
kerbside Posted April 12, 2006 Report Share Posted April 12, 2006 Anti roll bars are generally used to tighten (decrease roll, like Xfyffes pointed out)suspension without playing about with the spring rate or shock absorbers. As with all suspension mods on a fast car, if you do them well they will make the car better and if you make an @rse of it you will know about it. In the case of pretty much all TVRs, they are prone to oversteer so it would be common practice to modify the front drop links and anti roll bar to stiffen the front and make the rear grip better but if you overdoo it the grip at the front will be less causing it to slide and ending up with understeer. But the term drop link usually refers to the small metal rod connecting the anti roll bar to the suspension arm. Link to comment Share on other sites More sharing options...
MrBlues Posted May 7, 2006 Report Share Posted May 7, 2006 Hi Ari some interetsing info and pics here http://www.thegriffithpages.com/modifications/chassis-modifications/s-heath-drop-links.html and here https://delta.securesslhost.net/~shenglt...ace43747cc1d8ed Link to comment Share on other sites More sharing options...
