jitvv Posted April 28, 2006 Report Share Posted April 28, 2006 Hi Guys, I have got a problem with my S3 210 Facelift is running lean the MAF was changed in January and the Temp sensor has been changed. When i bought the car it was already chipped and the preavous owner told me it was a REVO chip, My Garage now think its the MAP that is causing it to run Lean at the top end of the rev range?? Any ideas? or anyone had a simlar problem? Cheers Jit. Link to comment Share on other sites More sharing options...
DuncS3 Posted April 29, 2006 Report Share Posted April 29, 2006 How do you know its running lean (so we cant help you more)? Obviously running lean is a big issue on these engines so take it easy until you get it sorted. Dunc Link to comment Share on other sites More sharing options...
jitvv Posted April 29, 2006 Author Report Share Posted April 29, 2006 I found out it was running lean when i had it rolling roaded the first time about 3-4 weeks ago but since then i changed the temp sensor as my Temp gauge was all over the place so i thought is was faulty. I had it rerun on Wednesday, And they told me it was still running Lean at the top end of the rev range. They think it’s the MAF. I explained that a new one was fitted in January. They then said it could be the Chip. They advised me to change the MAF again as this is cheaper than a remap. Just wanted know if any of you guys of had a Similar problem? Link to comment Share on other sites More sharing options...
DuncS3 Posted April 29, 2006 Report Share Posted April 29, 2006 Where abouts are you based? If in the South East you could try calling www.vagcheck.com - they can check your car out for you and tell you if its running lean by using vag-com - might be worth a try? Dunc Link to comment Share on other sites More sharing options...
Cupramax Posted April 30, 2006 Report Share Posted April 30, 2006 MAF's have been known to faulty when new... Have you spoken to Revo? From experience its unlikely to be their map at fault and they may well have a look at it for you. Speak to their head office... Link to comment Share on other sites More sharing options...
jitvv Posted April 30, 2006 Author Report Share Posted April 30, 2006 [ QUOTE ] MAF's have been known to faulty when new... Have you spoken to Revo? From experience its unlikely to be their map at fault and they may well have a look at it for you. Speak to their head office... [/ QUOTE ] Thanks that's a good idea i'll give them a call on Tuesday! I think i will try a new MAF as your the second person to tell they can fail very quickly! Cheers guys for you advise. Jit. Link to comment Share on other sites More sharing options...
