guner2980 Posted April 28, 2006 Report Share Posted April 28, 2006 if i have had the 6063 update on the mk4 r32 if so how Link to comment Share on other sites More sharing options...
UweRoss Posted April 29, 2006 Report Share Posted April 29, 2006 What's the 6063 update? An ECU firmware version? If so, just acess the ECU and look in the Component field. ECU firmware version will be at the end of the field. -Uwe- Link to comment Share on other sites More sharing options...
Paul Posted April 29, 2006 Report Share Posted April 29, 2006 Uwe, it is indeed a ECU firmware update/flash from Volkswagen dealers to solve some hesitancy/ flat spot issues with the R32 V6 Link to comment Share on other sites More sharing options...
jimmyp Posted April 29, 2006 Report Share Posted April 29, 2006 6463 not 6063... Link to comment Share on other sites More sharing options...
Paul Posted April 29, 2006 Report Share Posted April 29, 2006 Jimmy Is that a mistake on Gee_r32's part? or on mine? are there 2 updates? Link to comment Share on other sites More sharing options...
jimmyp Posted April 29, 2006 Report Share Posted April 29, 2006 Gee made the mistake Paul, the update is 6463, and you are correct that it does cure the hesitation issue that the car had, tho some dealers call it a different update ie, version 001, 1234,etc if you get my drift but most dealers should no what you are talking about if you mention the hesitation and 6463. HTH jimmy Link to comment Share on other sites More sharing options...
Paul Posted April 29, 2006 Report Share Posted April 29, 2006 Cheers mate Link to comment Share on other sites More sharing options...
guner2980 Posted April 30, 2006 Author Report Share Posted April 30, 2006 sorry lads my mistake but still havent got an answer? can i tell with vagcom if its had an update Link to comment Share on other sites More sharing options...
slol Posted April 30, 2006 Report Share Posted April 30, 2006 Yes it will show it when you select control module,then engine,in the coding part it will end in 6463 if you have the update, mine reads MOTRONIC ME7.1.1 6463 Link to comment Share on other sites More sharing options...
guner2980 Posted April 30, 2006 Author Report Share Posted April 30, 2006 nice one owe u one Link to comment Share on other sites More sharing options...
