Nelson_R32 Posted June 2, 2006 Report Share Posted June 2, 2006 Wrightio, reading your posts it seems your having trouble even fitting the N module version? It may be that your car is one of the few (early models) thats needs the 90cm long piece of wire for the steering column. I haven't got any instructions on me at the moment but Shark should have some in the post to him tomorrow Link to comment Share on other sites More sharing options...
paul_tdi Posted June 2, 2006 Author Report Share Posted June 2, 2006 This could be possible!! I am at a complete loss now! It is a 2002 car so was hoping that all the loom etc would be in place! Look forward to hearing the news. Interestingly I can see changes in code at the ECU when I play with the stalk?! I am very open to any suggestions and pointers as it is a constant learning process and it is really good to see that everyone here pulls together to solve these issues! I am chuffed I am now able to enable DIS which I hope to be able to help others out with etc! I think if we can get it all sorted it will put both mine and Bens mind at rest! Oh and the wife!!!! thanks for the contact, as always very much appreciated! Paul Link to comment Share on other sites More sharing options...
Nelson_R32 Posted June 2, 2006 Report Share Posted June 2, 2006 Paul, it sounds like yours may definately be without a wire I can supply you the wire and fitting instructions to do it but its part of a £40.00 kit that includes a new Cruise stalk and bolts etc. YHPM Link to comment Share on other sites More sharing options...
paul_tdi Posted June 2, 2006 Author Report Share Posted June 2, 2006 MOre money shh she might find out!! Have replied to the PM u sent! THANKS for the help and support!! Link to comment Share on other sites More sharing options...
jlast Posted June 2, 2006 Report Share Posted June 2, 2006 Maybe a silly question, I would like the DIS but ain't too fussed about cruise, is retro fitting the DIS only any easier? What parts do you need for just the DIS? Link to comment Share on other sites More sharing options...
UBM Posted June 2, 2006 Report Share Posted June 2, 2006 PM Shark90! Link to comment Share on other sites More sharing options...
paul_tdi Posted June 2, 2006 Author Report Share Posted June 2, 2006 It all depends on the module u have in the car! Ben (shark 90) helped me out loads! I can do it now but only the B6 model! The stalk was about 60 quid from the dealer and as my cruise does not work at present and DIS does it would suggest the DIS can be installed. The B7 programming needs a specific programming CAN bus cable. Link to comment Share on other sites More sharing options...
jlast Posted June 2, 2006 Report Share Posted June 2, 2006 Will do, thanks Link to comment Share on other sites More sharing options...
UBM Posted June 2, 2006 Report Share Posted June 2, 2006 Good luck fitting it! Link to comment Share on other sites More sharing options...
jlast Posted June 2, 2006 Report Share Posted June 2, 2006 From this post, I'll need more than luck It's not fair why is my neighbour NOT an Audi technician! Link to comment Share on other sites More sharing options...
paul_tdi Posted June 3, 2006 Author Report Share Posted June 3, 2006 There are plenty of people here that will help u out!! Ben (shark_90) did more than I would have expected from a dealer to help me out with my cruise etc. Good luck you will get it sorted somehow!!! Paul Link to comment Share on other sites More sharing options...
shark_90 Posted June 3, 2006 Report Share Posted June 3, 2006 Cheers for the praise Paul! Nelson - I'm not sure Paul's car might be one of these "odd" cars that do need an extra wire, mainly because it's not actually that early (52 plate) and because there was a fault code for the cruise stalk when I did the initial scan of his car last weekend. After speaking to Paul I don't think the code has come back, but I'm not sure. Is the information for this bit of wire in the instructions I shall be receiving? Obviously one I've got to be aware of Link to comment Share on other sites More sharing options...
paul_tdi Posted June 3, 2006 Author Report Share Posted June 3, 2006 HI Ben, Going to check for faults etc tomorrow as used the car a little today. Worth trying on the provision that if this aint it I can then go guns blazing to audi! Worth a try and Neil knows it is a 52 plate car so we shall see what happens! He is selling me a complete cruise stalk setup so will try that too! Hope u have had a good weekend matey! Paul Link to comment Share on other sites More sharing options...
timps Posted June 4, 2006 Report Share Posted June 4, 2006 Not sure if this helps but the guy that fitted cruise on my B6 said he had a real nightmare the month before and it turned out to be a faulty or non existent (cannot remember which) clutch pedal switch which would not let the cruise activate. He now checks that first on any problem cars. Link to comment Share on other sites More sharing options...
shark_90 Posted June 4, 2006 Report Share Posted June 4, 2006 Timps you might be on to a winner there, it never crossed my mind. I've just had to change that very part on my car. Good thinking Link to comment Share on other sites More sharing options...
paul_tdi Posted June 4, 2006 Author Report Share Posted June 4, 2006 HI Timps! You have just made mine and Bens day! Problem sorted! It is the blue switch that sits above the clutch pedal. Now bypassed and hey presto cruise we have!! Thanks very much for the pointer and it is nice to have a reasonably cheap fix for a change! Now that cruise and DIS is retro fitted and running 100% what next...... Link to comment Share on other sites More sharing options...
shark_90 Posted June 4, 2006 Report Share Posted June 4, 2006 Good shout Timps, like I said I can't believe I didn't think of that, even though I had to change the clutch switch on mine only yesterday Paul - BOSE next Link to comment Share on other sites More sharing options...
paul_tdi Posted June 4, 2006 Author Report Share Posted June 4, 2006 HI Ben, Keep us posted as at to how u get on as after having BOSE would love it again! Mind u might see if the BOSE speakers I have can be put in for now! Ideally if u source the amp and speakers I suspeect it may be worth seeing if u can get the necassary looms with it too?! Chuffed to bits we now sorted the problems with the cruise and that I too am able to do the cruise and retro fit of DIS and cruise! After reading a few threads etc might have to purchase the RS4 uprated rear roll bar!! Sounds well worth it! In the mean time looking forward to the next retro ideas!!! Link to comment Share on other sites More sharing options...
shark_90 Posted June 4, 2006 Report Share Posted June 4, 2006 Paul - do the bar, it's a MUST! Best £90 I've ever spent Ring Martyn at VAGParts for it Link to comment Share on other sites More sharing options...
timps Posted June 4, 2006 Report Share Posted June 4, 2006 Glad I could help Link to comment Share on other sites More sharing options...
Will22 Posted June 4, 2006 Report Share Posted June 4, 2006 If you think Bose is good you should try the Bang & Olufsen in the new S8 Link to comment Share on other sites More sharing options...
Mitchet Posted June 5, 2006 Report Share Posted June 5, 2006 Ben / Paul, What did you guys do in the end about the screenwash warning? I heard you mention about fitting the sensor, or have you just grounded the pin? Link to comment Share on other sites More sharing options...
paul_tdi Posted June 5, 2006 Author Report Share Posted June 5, 2006 HI Mitchet, We have both grounded the pin but will install the sensor soon as I have one! Have u grounded your pin ok? It is a little awkward etc but not the worst job! As soon as I get a sensor and install I will let you know! Paul Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2006 Report Share Posted June 5, 2006 Yep, mine's grounded for the moment. Can't be that difficult to fit the sensor but to be honest I don't know if I'll bother for now. It's just nice not to have the fecking car beeping every time it's turned on! Link to comment Share on other sites More sharing options...
Mitchet Posted June 6, 2006 Report Share Posted June 6, 2006 I haven't grounded the pin yet purley down to the lack of free time I've had recently. Out of interest, what did you use as the ground connection? Link to comment Share on other sites More sharing options...
