Golf 1.8T Gti - cambelt change advice
harminder
Can someone please confirm what mileage my 2000 golf 1.8T gti should have a cambelt change?
Currently car is just about to hit 60k and so was due a service. I was not sure if I should be getting the cambelt changed at the same time or wait until 80k?
I have also heard somewhere that 100k is ok before the belt is changed? confused.gif
Holy sh*t - I've never ever let a car run that long before without a cambelt change.
Despite Mulkbear's note, Baz, (he's a VW tech so he knows the VW guidelines) I would recommend it's done at 60K miles and then every 40K after that.
All I would add is that you don't want to know the damage it can cause if it goes - as Mrs Mook found out when we had a high mileage Golf TDI which had allegedly had the cambelt changed at 60K. 80K and it broke. £1600 later and it was back on the road...
There's a big difference between the TDI engine and the 18t petrol engine. There's far less load on the cam belt for a start (given the pd injectors are driven off the cam belt) and due to the high compression ratio of a diesel the valves occupy the same space as the piston at tdc, only not at the same time. I don't know for certain about the 1.8t, but I know some petrol engines can snap a belt without any damage to engine components. The Ford 2.0ltr pinto is one which springs to mind, but I've not had a petrol car since my old Mk1 RS2000 way back when, so I don't know about any others lately.
Thanks guy - I think to be on safe side I will get it done on 60k service! 169144-ok.gif
Is their anything else that would need to changed at the same time (i.e water pump)?
Also the car seems to be running fine but it does sound a little off at idle.....more like a diesel than a petrol sometimes so just wandering if I should mention that before I give the car in? UHOH7.GIF
  • 3 weeks later...
  • 3 years later...
My 2001 Golf GT TDi 115bhp is at 120,072 miles on the clock and is due for a cambelt change. It is booked in a queue after the new year, though someone please tell me, am I right to refrain from using the car until after the change or do you think it'll be ok as long as I get it done asap??? The last change was at 57,000 miles 5 yrs ago. Is the number 60k miles a maximum amount ie giving another 10k, not that I'd need the 10k, just maybe having the change at around 121,000 so I can get about until the change at the beginning of the new year
Edited by jouleskeys
  • 4 months later...
regarding the quote above, I have an A3, older model, petrol 1.8 but according to the service history my car had done about 80k miles without belt change. I have now changed it myself but I did have the diesel noise when at about 2k revs and more obvious if I reved the engine then let off the power and on the way back to idle the noise came. I was told by a mechanic m8 that it was the idler on the way out and should change it asap. I drove it (tentatively) for about a week before changing it but was hair raising stuff as can cause big damage if the belt does go.
  • 1 year later...
