shipy Posted May 29, 2006 Report Share Posted May 29, 2006 Just buying an A4 1.8 S-line quattro saloon, anyone know if it possible to fit the factory cruise control and whats needed. Also what else is possible to retrofit Link to comment Share on other sites More sharing options...
Nelson_R32 Posted May 29, 2006 Report Share Posted May 29, 2006 I can supply the retrofit kits (with full instructions) for £142.50; Your only problem is that you will need VAG-COM or once installed a Dealer to programme it into the car. Link to comment Share on other sites More sharing options...
shark_90 Posted May 29, 2006 Report Share Posted May 29, 2006 Or me, of course Link to comment Share on other sites More sharing options...
shipy Posted June 3, 2006 Author Report Share Posted June 3, 2006 Got the car now and its fantastic but this is somthing i'm going to have to do its to easy to let the speed creep up in 6th. Where are you based Shark, i'm down in the sunny west country. Does the B7 1.8t need the new vag com lead? Link to comment Share on other sites More sharing options...
shark_90 Posted June 3, 2006 Report Share Posted June 3, 2006 Yes, it does need the newer CAN lead for the B7. I am up in Notts but travel all over the place and often work in Bristol. However your best bet is to speak to stratty31, send him a PM as he doesn't spend a lot of time on the forums as he is a busy man, but I'm sure he'll be able to sort it out for you Link to comment Share on other sites More sharing options...
nordberg Posted June 5, 2006 Report Share Posted June 5, 2006 Do you need to remove the steering wheel to vit cruise on the B7? Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2006 Report Share Posted June 5, 2006 Very much so. Steering wheel off, cowling off, steering angle sensor off, steering wheel control module out + replace, fit stalk, replace with different cowling, put steering wheel back on. Link to comment Share on other sites More sharing options...
TDiAvant Posted July 25, 2006 Report Share Posted July 25, 2006 Nelson you have PM Do the instructions include the vag-com programming? if not how easy is it to program? Link to comment Share on other sites More sharing options...
shark_90 Posted July 25, 2006 Report Share Posted July 25, 2006 The instructions don't cover vag-com, because the dealership's systems don't work in the same way. The programming is reasonably difficult as the ABS controller forgets its coding when you replace the steering wheel control module. If you don't get the coding right the incorrect coding on the controller will cause the ABS, EBD and ESP to stop working altogether. Bear in mind you also need the correct coloured steering wheel cowling to accomodate the new cruise stalk. Link to comment Share on other sites More sharing options...
TDiAvant Posted July 25, 2006 Report Share Posted July 25, 2006 Has someone on here done the programming for the B7, or can recommend a dealer that would do it for me? I know Teesside Audi would not do the job, and I would never go back to Newcastle Audi. Link to comment Share on other sites More sharing options...
shark_90 Posted July 25, 2006 Report Share Posted July 25, 2006 I could do it for you. Link to comment Share on other sites More sharing options...
kite Posted July 25, 2006 Report Share Posted July 25, 2006 Ben, you need to get to Windsor Link to comment Share on other sites More sharing options...
TDiAvant Posted July 25, 2006 Report Share Posted July 25, 2006 Cheers, I will take your up on that offer Just waiting to hear back from neil regarding the parts. Will the programming have to be done immediately after the stalk has been fitted? As I would install the stalk first, then drive up to your area for the programming? Link to comment Share on other sites More sharing options...
barney0001 Posted July 25, 2006 Report Share Posted July 25, 2006 NelsonA4Sline, do you do CC for the b6 too? the guys at awesome said they couldnt do it? if the answer is yes, i have a VAGCOM cable, do the instructions cover the VAGCOM setup too? thanks. Link to comment Share on other sites More sharing options...
timps Posted July 25, 2006 Report Share Posted July 25, 2006 The instructions for VAG com for the B6 are on this post about halfway down Link for B6 Link to comment Share on other sites More sharing options...
shark_90 Posted July 25, 2006 Report Share Posted July 25, 2006 I honestly despair sometimes! Yes it can be done, it's not particularly easy but you should get by with the instructions I've written in the post that timps kindly linked to if you're pretty confident with VAG-COM. I also do a fully fitted service now, if anyone is interested. Link to comment Share on other sites More sharing options...
shark_90 Posted July 25, 2006 Report Share Posted July 25, 2006 [ QUOTE ] Cheers, I will take your up on that offer Just waiting to hear back from neil regarding the parts. Will the programming have to be done immediately after the stalk has been fitted? As I would install the stalk first, then drive up to your area for the programming? [/ QUOTE ] The programming doesn't have to be done immediately, but your ESP won't work at all (ABS, EBD, ASR etc) once you've changed the steering control module. So whether you want to fit it and then come down, or whether you want to bring the bits with you, or get the bits from me (I probably have the required parts already at home) is up to you I'm in Worksop in Notts, funnily enough I'm working in Stockton on Thursday if that helps you at all. Link to comment Share on other sites More sharing options...
barney0001 Posted July 25, 2006 Report Share Posted July 25, 2006 sorry shark_90 i admit i didnt read it all , i was just skimming during my dinner time, my enthusiasm overtook reasoning (and it was 33c where i was) i mean i didnt even search!! thanks timps for the link i applaud you, and other peoples efforts regarding this topic, i probably will go for this after current projects, I do alot of motorway miles. Link to comment Share on other sites More sharing options...
TDiAvant Posted July 25, 2006 Report Share Posted July 25, 2006 [ QUOTE ] funnily enough I'm working in Stockton on Thursday if that helps you at all. [/ QUOTE ] I wish I could do Thursday, but I getting hitched.... not being funny but I will be glad when it's all over. This wedding has been stress from the start and it’s getting worse the closer to the day. Talked with nelson today and he's getting the parts shipped out so should have them in the next few days. Will send you am PM when they have arrived, as I defo do not what to drive around without ESP, ABS, etc. Thanks Lee Link to comment Share on other sites More sharing options...
shark_90 Posted July 26, 2006 Report Share Posted July 26, 2006 Barney - no worries mate Lee, just give me a shout when you're ready Link to comment Share on other sites More sharing options...
TDiAvant Posted August 21, 2006 Report Share Posted August 21, 2006 Well Shark_90 installed cruise control on my B7 yesterday, and did a great job If anyone is thinking about this retrofit, then I would defiantly get it done. Link to comment Share on other sites More sharing options...
shark_90 Posted August 21, 2006 Report Share Posted August 21, 2006 Thanks mate, can only apologise again for the total mess of a day that you got dragged into! Thanks a lot for being so understanding Link to comment Share on other sites More sharing options...
TDiAvant Posted August 21, 2006 Report Share Posted August 21, 2006 No problem, I’m just glad you were able to complete the installation, after wait that long for the AA I would have been well stressed Link to comment Share on other sites More sharing options...
shark_90 Posted August 21, 2006 Report Share Posted August 21, 2006 I am formulating my complaint as we speak. However, first things first, I need to eat, as I didn't have anything yesterday! Link to comment Share on other sites More sharing options...
P_G Posted August 21, 2006 Report Share Posted August 21, 2006 What's the crack Shark? I got whiff of this from the Impromptu Leeds mee thtread, did JC's car give up the ghost or something? Link to comment Share on other sites More sharing options...
