Oatz Posted June 3, 2006 Report Share Posted June 3, 2006 Dont ask me how I've managed to do it but.... how do you remove superglue from paintwork and also the metal sidekick plates?? First thought is T-cut.... Many many thanks in advance Link to comment Share on other sites More sharing options...
bazza_g Posted June 3, 2006 Report Share Posted June 3, 2006 dude, I daren't ask how you did that ! A quick google brings up this and this and this - best of luck Link to comment Share on other sites More sharing options...
Keithp Posted June 3, 2006 Report Share Posted June 3, 2006 Form some where i can remember some one telling me they used warm soapy water to separates some ones fingers after they had guled them togetet by accident . Worth a try before the serious abrasives. Keith Link to comment Share on other sites More sharing options...
Panman Posted June 4, 2006 Report Share Posted June 4, 2006 Generally the recommendation is Acetone (or nail polish remover)I'm not sure how it would go with your paint though Generally anything hydrocarbon based will get rid of superglue (So... Petrol, Thinners, you may even want to try bug and tar remover). Key point here... Don't rub any of this stuff into the paint, put the solvent (any of the above) on the glue, then try to pull it away as it "melts" other wise you have just created the worlds second hardest sandpaper..... Link to comment Share on other sites More sharing options...
Calm Chris Posted June 4, 2006 Report Share Posted June 4, 2006 If you have a nice coat of wax / polish on the area, I'd lay a rag over the area and pour hot water on to the rag. After a minutes soak, it should lift off using that meg handy tool- a thumb nail. Acetone, will burn plastic- not recommended Link to comment Share on other sites More sharing options...
Moschops Posted June 4, 2006 Report Share Posted June 4, 2006 I thought the metal side kick plates were actually bonded into the black plastic strip and will leave a right mess if pulled away from the plastic backing. The black plastic strip will peel off with care. Link to comment Share on other sites More sharing options...
Ruppe Posted June 13, 2006 Report Share Posted June 13, 2006 Oatz, how did it go? I have the same problem with my other car - but it is glue on fiberglass.... Any recommendations? Cheers Link to comment Share on other sites More sharing options...
R32TIM Posted June 13, 2006 Report Share Posted June 13, 2006 Super Glue Release good luck. ps.Use to soften glue and then start working at the glue. Brush, scrape, shave, peel, sand or whatever mechanical means is available to work the glue off. Reapply and continue to work at the glue. Link to comment Share on other sites More sharing options...
Oatz Posted June 13, 2006 Author Report Share Posted June 13, 2006 [ QUOTE ] Super Glue Release good luck. ps.Use to soften glue and then start working at the glue. Brush, scrape, shave, peel, sand or whatever mechanical means is available to work the glue off. Reapply and continue to work at the glue. [/ QUOTE ] Do you know whether its safe for paintwork? I haven't even had achance to try and remove mine as its been in the stealers for over almost a week and a half Link to comment Share on other sites More sharing options...
R32TIM Posted June 13, 2006 Report Share Posted June 13, 2006 Apply only a very small quantity and make sure you wash it off straight away and apply polish and wax.....i think it will eat into the clear coat if left on.... Link to comment Share on other sites More sharing options...
Oatz Posted June 13, 2006 Author Report Share Posted June 13, 2006 [ QUOTE ] Apply only a very small quantity and make sure you wash it off straight away and apply polish and wax.....i think it will eat into the clear coat if left on.... [/ QUOTE ] Thanks for this have you tried it yourself?? Link to comment Share on other sites More sharing options...
R32TIM Posted June 13, 2006 Report Share Posted June 13, 2006 yes, but not on my car.... i'm not sure about it eating through the clear coat but thats what i was told at the time. Easy job, just apply small quantities.....you could even try 'pealing' the glue off with a sharp chisel....but you will need hands like a surgeon..... Link to comment Share on other sites More sharing options...
